New brake hoses?
Old Apr 6, 2016 | 10:15 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default New brake hoses?
OK, I'll admit it, I like to tinker with, as well as improve/maintain my car(s). My C-5 is a low mileage, '01. It's been sitting out the winter, and hopefully I'll get it back on the road within the next couple of weeks.
As usual, I'll do the annual brake fluid flush, and since I'll be in there, I was thinking about maybe replacing the brake hoses, as they're now 15 years old. A couple of questions arise, of course....
Number one, do they really wear out/dry out severely, just due to age? The car has 25,000 miles on it. Number two, if they should be replaced, what's better for a street car, OE rubber or stainless braided? If stainless, there are several brands out there, and some use banjo fittings, while others use AN fittings. What's best?
TIA!
Old Apr 6, 2016 | 02:07 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I just replaced mine with steel braided(99 with 67,000) the rubber can expand and with age burst !!! Guys who have changed them say they get much better brake pedal feel(firm) I have not driven mine yet ??? If you have Active Handling you should use a Tech 2 for bleeding ???
Old Apr 6, 2016 | 02:09 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Tech 2 Bleed !!!!!
https://www.corvetteforum.com/forums...h-2-bleed.html
Old Apr 6, 2016 | 02:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the outside rubber hose isn't damaged/ cracked or weather checked, there no reason to mess with them.
However, that being said, If you want a better brake pedal feel , you can get bradded hoses.
ALWAYS change the fluid completely if you do any brake system maintenance. The TECH 2 makes it easier but, you can do the service without one. JUST DON LET THE MASTER RUN DRY when you bleed the slaves!!
Old Apr 6, 2016 | 06:06 PM
leadfoot4's Avatar
leadfoot4
Thanks for the info, guys!
Maturity is defined by the age old statement......if it ain't broke, don't fix it! I think I've matured a little, over the years.
I do have the F45 suspension (why I ordered it, I'll never know.....well, I do, but that was 15 years ago. I know better now), and I don't have any problems at the moment, so maybe I'll just leave things alone. I will, however, change the brake fluid, using the vacuum pump that I've been using in the past.....
Now if the weather will just warm up, and not snow any more!!
Old Apr 6, 2016 | 06:50 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What does APRIL SHOWERS bring? Dead flowers and dead Daffodils LOL!!!
Yep,,, the weather SUCKS!!
Old Apr 6, 2016 | 06:52 PM
leadfoot4's Avatar
leadfoot4
In my area, April showers turned to April snow, which turned into April road salt.....
To New brake hoses?
