Rear Cradle Bolt Spins
Old Apr 11, 2016 | 12:06 PM
10yrPlan's Avatar
10yrPlan
Default Rear Cradle Bolt Spins
2001 Convertible
Manual Trans
~88,000 miles.
Just bought the car in March.
I have removed the rear cradle and Diff to fix the leak at the extensions housing and transmission. I will also replace the rear Diff O-rings and seals and extension housing to Diff O-ring. When removing the cradle, one of the mounting bolts was spinning. We were able to get the nut off and cradle out. I have search and cannot find any posting of others with this same problem, or suggested repair. I can get the bolt to it's "home" position, but when I put the nut on it will raise up and start to spin.
Any ideas? I was thinking of trying to get some JB weld up inside the mount and tighten the nut to hold the bolt down and let the JB weld cure.
Thanks in advance -
Old Apr 11, 2016 | 12:26 PM
StingrayRebel's Avatar
StingrayRebel
did you use an impact to remove the nuts??... there is a rivet that holds the stud in place and if it breaks the stud will spin freely, I believe you have to cut into the frame to repair it... you might try putting the cradle in place, get the nut started, and then use some large vice grips or locking pliers on the end of the stud to hold it in place while having a helper tighten the nut
Old Apr 11, 2016 | 12:46 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
SOMETIMES the retainer breaks and that is what causes the issue. If anyone used an electric or pneumatic hammer to remove the NUTs,, that's what normally breaks the retainer clips
Here is what the bolt retainer clip looks like on the FRONT CRADLE:
FRONT CRADLE BOLT retainer ON A C5:
Old Apr 11, 2016 | 03:25 PM
10yrPlan's Avatar
10yrPlan
I did use an impact driver to remove the nuts. I'm a big fan of impact drivers to remove nuts and bolts over a ratchet, wrench or breaker bar; if they don't want to move, they the impact driver will not break the bolt. Typically I will spray with penetrating oil and start the impact driver on the lowest setting and work my way up until the nut or bolt starts to move. Looks like in this case it was a bad idea (?). I read about not using an impact driver to install the nuts so you don't break the mount of the bolt, but I don't recall reading about not using one for removal...
I'm sure the cradle has bene off before, maybe it wasn't me that broke it...
Good to know anyway.
New seals shipped out today, should be back on the road by the weekend.
Old Apr 11, 2016 | 03:26 PM
10yrPlan's Avatar
10yrPlan
[QUOTE=Bill Curlee;1591973780]SOMETIMES the retainer breaks and that is what causes the issue. If anyone used an electric or pneumatic hammer to remove the NUTs,, that's what normally breaks the retainer clips
Thank you of the picture. Good to know that's what it looks like.
Old Apr 11, 2016 | 06:02 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
DO NOT USE AN IMPACT ON THE CRADLE NUTS.... That statement is littered through out this forum....
I'm a fan of air tools too, but never ever use them on these nuts. I'd put money on it that it broke when you put the impact on it.
Old Apr 11, 2016 | 06:15 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
cut open the frame and weld them back it back in place.
Old Apr 11, 2016 | 06:39 PM
Smoken1's Avatar
Smoken1
Old Apr 11, 2016 | 07:00 PM
10yrPlan's Avatar
10yrPlan
Roger that-
May others learn from my mistake
Old Apr 11, 2016 | 11:55 PM
lionelhutz's Avatar
lionelhutz
The proper way to fix it is to cut a hole in the floor above the bolt and fix the attachment. The rear attachment is the same as the front in the picture Bill posted.
But then if it's a rear bolt take a look in by the rear upper a-arm mount. I've never paid attention, but maybe you can jamb a flat head wrench in there to hold the bolt head.
Old Apr 12, 2016 | 07:20 AM
vettenuts's Avatar
vettenuts
Most people don't follow the service manual, but the nuts are not supposed to be re-used either. They are lock nuts.
Old Apr 12, 2016 | 08:11 AM
LoneStarFRC's Avatar
LoneStarFRC
Manual? We don't need no stinkin' manual...........
Old Apr 12, 2016 | 09:25 AM
VGLNTE1's Avatar
VGLNTE1
Ive never once bought a new bolt or nut for anything other than head bolts. Silly.
Old Apr 12, 2016 | 03:52 PM
tbrowne's Avatar
tbrowne
The Field Service Manual does not mention the need to replace the nuts on the cradle, as if it were possible anyway. Without a manual - you're just another person posting How To questions on forums and hoping you get the correct answers.
To Rear Cradle Bolt Spins
