Just bought two front o2 sensor extensions for a set of long tubes. I got the 24" my question is will that length cause any false readings due to signal degradation? I tried to find out what length I needed but couldn't find it so I just got the 24" to make sure I had enough length. Thanks
No, the length won't matter to the signal. Just make sure you securely tie up any excess length so the wiring doesn't drag or get burnt on the exhaust.
Length doesn't matter!
Make sure that you have full battery voltage on your OXY SEN fuse before you install a brand new sensor. Recommend reading the test slots on the fuse to chassis ground (ignition on). You should see full battery voltage.
....depending on who you ask. My fiance might debate with u on that! Haha thanks for the info.
