From 4'th to Reverse
Old May 11, 2016 | 04:13 AM
CorvetteC5Norway's Avatar
CorvetteC5Norway
Default From 4'th to Reverse
Have anyone tried to shift from 4'th to reverse on their 6m? Well, I have. On a spirited run on the autobahn together with my friend's 03 Z06, I stupidly tried to shift fast from 4'th to 5'th, and scraped into reverse twice before I understood what I did.
I have been happy with the tranny so far, but now that I've tried to use it on a track I understand why people change the shifters....
Anyway, the result is that sometimes when I try to engage into reverse, it has not moved completely into gear. If I just keep pressure on the gear lever when I let the clutch out, it always pop into gear and it does never jump out of gear. So it's no big deal and I will not do anything with this now, but maybe in the winter.
Does anyone know what probably have happened? I know there is a unit inside the tranny which we call (dir translated) shift fork. My guess is that it has been bent a little so that it sometimes is not able to push the gears completely into place for reverse (no other issues with 1-6)
Old May 11, 2016 | 09:05 AM
grantv's Avatar
grantv
No other issues? It's allowing you to shift from 4th to R, reverse lock out solenoid must be pooched. No way my factory shifter could shift into reverse by mistake.
Old May 11, 2016 | 09:09 AM
CARRJET's Avatar
CARRJET
sounds like your reverse solenoid is sticking
Old May 11, 2016 | 09:32 AM
CorvetteC5Norway
This solenoid, is it hard to get to? Should it throw a code?
Appreciate the help!
Old May 11, 2016 | 10:18 AM
grantv's Avatar
grantv
IIRC it's on the passenger side close to the shifter. Maybe have to remove the tunnel plate, mid-pipe? Somebody more knowledgeable than I will post soon hopefully...
Old May 11, 2016 | 10:51 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ive seen this happen NUMEROUS times on other peoples C5 and for that matter C6s
There are SEVERAL things that contribute to the issue.
1. You need to TEST the REVERSE LOCK OUT SOLENOID.
Its quite easy. Get the car going down the road at a speed of say,,, 30 MPH. Shift the transmission into Neutral. While the car is coasting down the road, PUSH the shifter handle into the 5th/6th GATE. The shift handle should NOT go into the REVERSE gate! If you apply FORCE to the shift handle, it SHOULD push further into the reverse gate.
NOTE!! As long as you don't PUSH the shift handle FROWARD into the actual REVERSE GEAR it SHOULD NOT GRIND. You are just seeing if the actual reverse lock out prevents the shift handle from entering the reverse gate. If its working correctly it should NOT be easy to push it into that gate. It takes a LOT of force to push past the lock out.
2. OK,,, This is where it gets Personal. You SHIFT TECHNIQUE SUCKS! If you are using the DEATH GRIP on your shift ****, and FORCING it into the shift gates you are going to have shifting issues.
Wait till you are winding out third gear and go to slam it into 4th (and because you have a death grip on the shift ****) you pull the shift handle towards your body and actually shift into SECOND GEAR! As your engine MECHANICALLY REVS to 9000 RPM and you bend all your push rods, you will start to invent NEW cuss words!
Take a look at the video in this HINSON C5 SHIFTER post. The driver has a pretty good shift technique " PALM of HAND & TIPS of FINGERS"! Once you master this, it difficult to make a mistake.
https://www.corvetteforum.com/forums...in-action.html
3. On another note, YES! You also need a BETTER SHIFTER. I purchased a KIRBAN Shifter. It has ADDITIONAL shifter rod CENTERING SPRINGS and when you BUMP the handle out of gear, the shift handle IMMEDIATELY springs into the 3rd/4th Neutral gate, ready for action... There are MANY good Shifters out there. KIRBAN, MGW, HINSON ect... You need to pick one. I like the additional shift handle centering force provided by shifter with centering springs. Some people don't!
When you have issues engaging REVERSE or any gear for that matter, a couple things come to mind.
1. The synchros and are worn enough that it makes engaging the gear difficult.
2. Theres an entire post on this issue: https://www.corvetteforum.com/forums...verse-fix.html
Bill
Old May 11, 2016 | 10:54 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a picture of your transmission. The solenoid on the passengers side that is attached to the BOX on top of the trans is the REVERSE LOCK OUT SOLENOID
The other solenoid is for the CAGS feature.
Old May 12, 2016 | 04:17 AM
CorvetteC5Norway
Thanks Bill, that was informative. My tranny worked perfect until my "mishap". Still no popping out of reverse, just that I need to keep pressure on the gear lever when letting the clutch out to be sure that the reverse is engaged. It will probably get worse, but I will wait until winter before fixing it.
This soleniod, can you access it from under the car or do you need to remove panels in the cockpit?
Old May 12, 2016 | 03:34 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would say that you would need to at least lower the rear cradle and lower the drive train down to the MAX angle to get the proper clearances. There are NOT any interior panels that can be removed!
So,,, its all done from under the car.
Examine the DTCs (by using the DIC) and see if you have a DTC P-0801, Reverse Inhibit Control Circuit Malfunction.
Report results
Old May 12, 2016 | 07:22 PM
tentuna's Avatar
tentuna
Did the reverse lock out solenoid on my 04 Vert last fall, while its not easy, you can do it by feel without loosening the cradle. bought a GM replacement on Amazon total cost was ~$75. Just be careful not to drop the socket or bolt for some reason 10mm stick in my memory and problem is solved.
Old May 13, 2016 | 06:55 AM
CorvetteC5Norway
I tried yesterday to push it into the reverse gate in 15-30 mph, and one time it stopped me, and the other time it didn't. At what speed should it kick in? What I wonder about is that I think it could be intermittent. I wonder if the 1-to-4 / CAGS system also is working intermittent. I'm not sure since that system is based on multiple factors....
Could this be a bad grounding issue?
To From 4'th to Reverse
