need help with window adjustments
Old Sep 6, 2002 | 10:40 PM
Bracket_Racer's Avatar
Bracket_Racer
Default need help with window adjustments
Anyone have a website address that shows how to adjust the drivers side window both up (front and back) and also tip in....The window does not seal to the convertible top so when the door is closed and the A/C on you can actually feel the air from the outside at the back upper edge of the window. sorry for rambling, not the most mechanically inclined, I will take this info to my mechanic in the A.M.
Thanks in advance!!
Old Sep 6, 2002 | 10:52 PM
MDT's Avatar
MDT
Default Re: need help with window adjustments (1Fast99Roadster)
1Fast99Roadster,
This just came up a couple of days ago.
http://www.***-internet.com/johndennington/how_to/window_tip_in.html
Edit: Looks like with that long URL, you may need to copy and paste in an address field.
Good luck.
Mark
[Modified by MDT, 10:50 PM 9/6/2002]
Old Sep 6, 2002 | 11:59 PM
MikeyD's Avatar
MikeyD
Default Re: need help with window adjustments (MDT)
I just scanned this info into Acrobat Writer. If you have Acrobat reader, then I can e-mail you the file. This came out of my '97 service manual but I'm sure it will work on just about any C5. Let me have your e-mail. :cheers:
Old Sep 7, 2002 | 01:42 AM
Bracket_Racer
Email me at: onefastc5@attbi.com
To need help with window adjustments
