Pulled my codes for first time
Old May 18, 2016 | 05:52 PM
RueBurgundy's Avatar
RueBurgundy
Default Pulled my codes for first time
These codes mean anything to anyone? I was trying to get to the bottom of my AH issues (triggering often and sometimes violently at highway speeds), but am not sure if these are related. I tried pulling immediately after AH is triggering but this is all I got. They are the same as when pulled cold. Anything else in here I should be worried about?
For context, I had minor radio work done (TransIt Bluetooth). Also had a dealer disable the F45 shocks. Also installed Corbeau A4 seats (BCM still in place. Seatbelt light flickers). That's about it for anything that might affect these codes? Also a Honker CAI..... and tune by Synergy. TPMS missing at the moment giving me the error message. That's all.
B0521 H
U1016 H
U1040 H
U1064 H
U1088 H
U1176 H
U1160 H
B0361 H C
C2100 H C
C2105 H C
C2110 H C
C2115 H C
Old May 19, 2016 | 01:10 AM
73Corvette's Avatar
73Corvette
You need to CLEAR the CODES... go for a drive then pull the codes BEFORE you KILL the MOTOR... and post them again
Old May 19, 2016 | 01:23 AM
BigGun's Avatar
BigGun
Originally Posted by 8VETTE7
We really need to know which sensor(s) the Uxxxx codes are listed under to help with those. ie 10 - PCM or 28 - TCS or 40 - BCM.....etc.
The B0521 is tachometer signal circuit malfunction.
The B0361 is an HVAC system error for the drivers side actuator (common on the dual zone climate control system)
The C21XX codes are 1 for each of the 4 TPMS that are missing.
Were there any sensors reporting NO COMMS?
AH triggering when it is not supposed to is most likely a SWPS that is getting ready to crap out. The SWPS is well known for causing AH symptoms and NOT setting a code until the finally go for good.
Tires that don't have the proper offset front to rear can also cause this problem. This would cause a problem with traction control but the symptoms would be similar. What tire sizes are you running?
Old May 19, 2016 | 09:38 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP,, TOO many old history DTCs to deal with... CLEAR ALL of them and see what comes back.
Go from there.
Bill
Old May 20, 2016 | 02:04 PM
RueBurgundy
OK, I'll clear them out and report back.
for reference
Tires: 275/35/18F, 295/35/18R.
TPMS are just reporting xx/xx, nothing about NO COMM.
The U-codes are all under 60-IPC
Old May 20, 2016 | 03:44 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
for reference
As Chuck (8VETTE7) pointed out your tire size could very well be an issue ???
To Pulled my codes for first time
