no start will not crank
I plugged an bod 2 into it & it said I had no codes but I know for a fact the low pressure sensor on the bottom was out when I made the read,
the onboard DIC says I have none, but I know they didn't just fix itself
http://www.stengel.net/diccodes.htm
Maybe you could explain your problem a little better.
NORMALY ,,, If there is an engine sensor or component that is not allowing the engine to run, it will show up as a DTC. You should ALWAYS READ the DTCs using the cars onboard computer. You should always read the DTCs "BEFORE" you turn off the ignition switch as some DTCs can and will clear at each ignition cycle.
The PCM DOES NOT monitor FUEL Pressure or SECONDARY SPARK.
You should verify that you actually have fuel pressure using a fuel pressure GAGE and that you actually have SPARK at each bank.
IF, the car has a security related issue "VATS or other PCM/BCM issue, you SHOULD see a DTC for those functions
NO,, The Low Oil Level switch OR the Oil Pressure Sensor WILL NOT cause the engine not to run.
My oil pressure sensor showed ZERO OIL PRESSURE (because I had no 5 VDC reference to the sensor) and the engine started and ran fine. I had proper pressure in the engine but the PCM was NOT being told that. She Ran just FINE!
Bill
