Switchback LED's
During the day, headlights off, they run amber. Directionals are amber.
When you turn the lights on, they run white. Directionals are amber.
The switchback has white for driving and separate amber for flashing in the same "bulb".
The result is what mrmagloo said above.
Normal DRL/Turn Signal Operation:::
DRLs ONLY burn when Park/Headlight are OFF.
Some C5s have the Ambient Light Sensor that turn off the DRLs at low light, but since it is getting dark, you would normally
turn on your Park/Headlights, anyway. Also, not all C5s have the sensor. My 2004 Z06 does not have it. The DRLs
will burn anytime the Park/Headlights are OFF, day or night.
DRLs and Turn Signals are on the SAME filament, so without any other added controls or harness, they will burn the
same filament and the same color. Parking Lights use the other filament, exclusively.
There are ONLY four options that can take place:
1. DRLs On
2. DRLs On, Turn Signal On
3. Parks On
4. Parks On, Turn Signal On
There are two styles of Switchback LED Bulbs:
1. AO = Amber - Off (Amber Only) Has a relay and a timer function so the Amber will only burn and keeps the White
Off until a short time after the Amber goes Off. Amber Turn Signal with White Parks On, will be
Amber-Off-Amber-Off....White Park. AO is preferred for normal C5 operation.
2. AW = Amber - White (Amber together with White) Just like a standard filament bulb. Amber Turn Signal with White Parks On, will be
Amber-White-Amber-White. Most Switchback LEDs, the White overpowers the Amber so you will see a BRIGHT White
and a DIM Amber flash. It will look as if only the White is flashing.
With Switchback LEDs you have two options:
1. White for DRL/Turn and Amber for Parks
2. Amber for DRL/Turn and White for Parks
That is it, without some other added harness or control
If you use a LED in place of any Turn Signal flashing bulb filament, you will need a resistor paralleled across that filament (usually a 6 ohm 50 watt), or
you will have hyperflash. Adding a Hyper Flash Flasher Harness will stop hyperflash without ANY resistors anywhere in the circuits. You will
still have hyperflash with the Emergency Warning Flasher, unless you have resistor across the Turn Signal bulbs.
CAUTION::: Resistors get HOT!! Mount them away from any other wiring, plastic, etc..
Any bulbs longer than about 2.5 inches WILL NOT fit in the front corner housing. Also, many LEDs have some of the LEDs on top of the bulbs. These will
be push up close to the top of the housing, and not produce ANY light.
You can splice in a normal LED flasher in place of the Hyper Flash Harness. Search site for the info.
I used this one so I can adjust the flash rate. Works Great:
Larry
I've already installed the hyperflashing harness. I am disappointed that I have not solved the issue. I am not inclined to splice wires in order to tackle the emergency flashing issue. I will have to live with a partial solution. Or, bother to add resisters to the turn signal LEDs which defeats the purpose of installing the hyperflash relay.
Your comment about Switchback LEDs. You described two options (below):
These the depend on polarity?
A third option could be to add a NA (Non Amber) LED. Use a white LED and have white light for DRL/Turn and Parks. Right?
I've never seen switchback LEDs that worked the #1 way for sale. Got a link?
Yes, they are polarized and yes to the clear (Non Amber) bulb operation.
http://www.stopforce.com/RPO.html
"Note: If your vehicle was built after Feb 02 you may or may not have the sensor installed from the factory required to make the T82 automatic headlamp function by simply turning it on in the cars BCM. A quick way to verify this is to remove (no tools required) the defroster vent on the center of your dash. There should be 2 sensors installed. The sensor on the right is for your climate control and the sensor on the left is for the T82 automatic headlamp control. If this sensor is not present it can be purchased from GM for about $12.00. The part number is 12450121 and it simply snaps into a space already provided on the defroster grill.
Next you need to find the pigtail that plugs into the sensor. It is on the right side of the steering column and has a piece of white tape holding it folded in half. Cut or tear the tape and leave it dangling down."
As stated, my 2004 Z06 does not have the sensor nor does it have the listing for it in the DIC Options nor does it have a T82 RPO on the RPO list. The DRLs work anytime the Parks are Off, day or night. It is my understanding that this is the T82 RPO for Automatic Headlamp function in the US. The Z49 Twilight Sentinel RPO is mandatory in Canada.
Colors not listed on the cheap ones? I've only seen the white running, yellow turn when listed but there are a few cheap ones where it doesn't specify. It's not a polarity thing though because putting them in backwards won't reverse their operation.
In normal use, the hazard switch is only used for the flasher and that is why the hyperflash harness can completely bypasses the hazard switch for the normal signals. The output of the flasher in the hazard switch goes to the multi-function switch which directs the power to the correct lights.
But, when using the hazard function the output of the flasher remains internal and goes to 4 contacts that are switched on to connect the corner lights.
You would have to remove the flasher circuit inside the hazard switch. Then a modified hyperflash harness could backfeed the flasher power into the hazard switch for use with the hazards. BUT, you'd have to have to key on for the hazards to work or have it wired so the signals always worked key on or not.
I tried putting a new flasher in parallel with the stock one but the stock one over rode the new one and still caused hyperflash. You could try it, it might work for you. Even then, you'd have to have the key on for the parallel flasher to force the slower flashing.
Don't know. Just checked my 2004 Owners Manual and it lists Twilight Sentinel as Optional in the US and Standard in Canada.
the chinese junk, today, you don't always get what is listed.
I have removed the bases and reversed the amber and white positive leads. That will reverse the operation.
Also, some listings don't say whether the bulbs are wired Standard or CK pin-out.
The 3057s are the first flashing bulbs I've swapped out since installing the flasher harness. The rear signal LEDs are working perfectly in all modes. If the emergency flashers are going while the left or right signal is engaged, there is a odd blip in the flashing, but that is it. Better yet, there are no resisters installed anywhere. Even the emergency flashers work without hyperflashing. I was not prepared for that, I expected the emergency flashers to go hyper.
Once the next set of LEDs to arrive I will tackle the bigger project of determining which LEDs perform best for the DRL/signals. Stay tuned.
When the turn signal is on is there any issue with the white light over-powering the amber as mentioned in one of the above post.
I have all the parts but don't have my car together yet.
