Switchback LED's
Old May 26, 2016 | 10:38 AM
phil hunter's Avatar
phil hunter
Default Switchback LED's
Thinking of installing Switchback LED's in my front turn signals to go along with my LED tail lights. The ones that are white, but blink amber. Anyway, I'm not sure if I need resisitors for them or not if I already have a hyperflash harness?
Thanks,
Phil
Old May 26, 2016 | 10:47 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Switchback
Thanks,
Phil
Contact Radio Flyer. I have a C6 and used their harness for my front switchbacks and it works and looks great. I know they make one for the C5. I assume your resistors are in the back so they will not work for the front.
Old May 26, 2016 | 02:40 PM
phil hunter
Thanks, but I don't really understand your answer. I have a hyperflash harness already installed in the vehicle to eliminate fast flashing in the rear LED's, so I'm wondering if I need the resistors for the front LED's since I think their purpose is to eliminate hyperflash?
Phil
lionelhutz's Avatar
lionelhutz
You don't need any resistors front or back with a hyperflash harness.
Old May 26, 2016 | 04:46 PM
2008 Corvette
Default Harness
You will need the harness for the front also. Contact Radio Flyer Inovations and ask him!
Old May 27, 2016 | 07:33 AM
MAC5's Avatar
MAC5
The existing hyperflash harness should handle both the front and rear.
Old May 28, 2016 | 06:00 PM
Mastertvtech's Avatar
Mastertvtech
Simply, if you already have led tail lights, you still may or may not have a hyperflash harness...The led's could have resistors on them...In that case you would need a harness or more resistors.
Old May 28, 2016 | 07:48 PM
2008 Corvette
Default LED switchback
If your harness is in the rear it will nothing for the front. As previously stated contact Radio Flyer Innovations on Tuesday and they can help you with the harness and switchback bulbs. Switchback harness is not the same as a hyperflash harness for the front. Contact on Tuesday and ask!
Old May 28, 2016 | 10:48 PM
GCG's Avatar
GCG
Thanks,
Phil
If you already have a hyperflash harness installed that's all you need. Only one is needed to avoid turn signal hyperflashing in all 4 corners.
Resistors are not necessary when a hyperflash harness is installed.
Old May 28, 2016 | 10:54 PM
GCG's Avatar
GCG
Check Corvettemods
Our revised switchbacks are the first of their kind. Instead of 60 (30 white/30 amber) small 1210 SMDs per bulb, the new switchbacks have 39 2826 SMDs per bulb AND each LED has the ability to illuminate 2 different colors -AMBER & WHITE!
What are the benefits?
  • Brighter - 39 LEDs for each color vs 30 on the old units
  • Smaller, nicer looking assembly
  • Each LED 1/3 larger for better dimensional output
  • New shielded technology
  • Most Reliable Performance
These advanced LED's allow you to have the amber color emitted during normal day driving, but when you turn on your headlights they switch over to white! This allows you to have a uniform look to your OEM HID headlights at night. Then, when the blinkers are triggered the bulb will switch to just amber to pass inspection!
Old May 29, 2016 | 10:32 AM
phil hunter
2008 Vette,
The hyperflash harness is under the steering column. It replaces the stock flasher. It is not in the rear of the car.
The switchbacks I want to use are white DRL's and turn amber when flashing.
Phil
Old May 29, 2016 | 11:09 AM
lionelhutz's Avatar
lionelhutz
Ignore 2008 Vette, he doesn't know what he is talking about.
All you have to do is plug any switchback LED you want into the front. Nothing else is required.
Actually, if you do go Ebay or Amazon then just make sure to not buy the alternate CK socket type LED's. You can easily find the good switchback bulbs for <$20 from a US source or around $10 if you get them from China (which is where the US sources get them from).
Old May 29, 2016 | 12:50 PM
GCG's Avatar
GCG
...The switchbacks I want to use are white DRL's and turn amber when flashing...
Check Post 10 above and http://m.ebay.com/itm/Type-2-3157-3757-3457-4057-3047-3357-dual-color-White-Amber-39-39-led-light-bulb-/170949499414?nav=SEARCH. They seem to be the same and what you are looking for.
Old May 29, 2016 | 01:24 PM
lionelhutz's Avatar
lionelhutz
You can find them way cheaper than that.
http://www.ebay.com/itm/3157-Type-2-...NWFX7a&vxp=mtr
or
http://www.ebay.com/itm/2X-High-Powe...lVSTzz&vxp=mtr
You should never need to spend over $20 for a set.
If you're OK with the ones that flash white-yellow-white-yellow then you can get them even cheaper, like $10 for the second type I linked shipped from China.
Old May 29, 2016 | 04:57 PM
RVETTE42's Avatar
RVETTE42
or
Don't want to disagree with you but bought some switch back's on eBay and they started flickering in Less than a couple months. Some times you get what you pay for.
Old May 29, 2016 | 05:41 PM
phil hunter
Mastervtech, I know I have a hyperflash harness because I bought it and put it in myself. I also installed the LED tail lights and they flashed too quickly, which is why I installed the hyperflash harness. Since I had the harness, I thought I'd install LED's in front also. Only wanted to know if I needed the resistors or not.
GCG,
No idea why the reference to post 10 above because it describes lights that are amber DRL's that turn white when the headlights are turned on. This is not what I'm looking for. I want lights that are white DRL's that flash amber as turn signals, like the ones you linked to on Ebay.
Now, anyone know if these will fit in the housings? Not interested in amber, white, amber flash.
Phil
Old May 29, 2016 | 05:57 PM
RVETTE42's Avatar
RVETTE42
[QUOTE=phil hunter;1592315082]Mastervtech, I know I have a hyperflash harness because I bought it and put it in myself. I also installed the LED tail lights and they flashed too quickly, which is why I installed the hyperflash harness. Since I had the harness, I thought I'd install LED's in front also. Only wanted to know if I needed the resistors or not.
GCG,
Go to Rado Flyers web site he has a plug and play harness to give you white LED driving lights full time in your DRLs location's. You will also need switch back bulbs but since you have hyper flash harness you need nothing else. If you use Radio Flyers 6 gen switch back bulb it will fit in your stock housing. but you can also purchase clear DRLs on line and make your bulbs even look brighter
To Switchback LED's
Old May 29, 2016 | 07:35 PM
lionelhutz's Avatar
lionelhutz
GCG,
Phil
You posted switchbacks, which is what was linked. The type 2 switchbacks are white running lights and flash yellow for the turn signal (not white-yellow-white-yellow). You never mentioned it, but there is no such thing as a switchback bulb that is white DRL, white running light and yellow turn signal because the DRL is the turn signal. You need to add another harness to get the lights to work like that.
Where do you think the specialty shops get theirs from? They just find a offshore source.
Old May 29, 2016 | 08:13 PM
2008 Corvette
Default Switchback
Tuesday is just 2 days away. Radio Flyer Innovations has your answer. Do not listen to Lionelhutz, I have Eagle eye LED,s in the rear and they have their own resistors as part of them. I have a switchback harness in both of the front DRL,s and Turn signal. Running light is white and turn signal is amber. Works great.
Old May 29, 2016 | 08:24 PM
phil hunter
OK
OK, not sure I understand what you guys are saying. Why do I need a Radioflyer harness??? There are several bulbs listed on Ebay and other places that claim to be white when the parking lights are on and amber turn signals are blinking. Are you saying that the bulbs will be amber as DRL's and white as parking lights? Aren't they the same bulb? It would seem to me they would be white in either case. Here is just one example of what I'm talking about:
http://www.ebay.com/itm/170949499414
Am I missing something here?
Phil
