2000 Corvette
Old Jun 14, 2016 | 08:43 PM
Tambo20's Avatar
Tambo20
Originally Posted by 73Corvette
CLEAR the codes ..go for a drive and then PULL the CODES BEFORE you kill the engine... post them here
Ok, I have not driven the car. I will clear all codes then take it for s ride. I will check codes while running and post them.
Old Jun 14, 2016 | 08:53 PM
foggy's Avatar
foggy
I would suggest replacing the fuel filter.. It's a regular maintenance item anyway, and
should be replaced regularly. So it's not a waste of time or money. Especially
if you don't know when it was replaced last. Make sure to use an AC Delco or WIX filter
since its the regulator too
Old Jun 15, 2016 | 03:30 PM
Tambo20's Avatar
Tambo20
I took the car out for about 15 minute ride. I got home and checked for codes while the car was running, there were no codes. but does run a little rough. I think I should change the fuel filter since I don't know when It was done last.. I will post after I get that done..
