04-z a/c help
Old Jun 19, 2016 | 12:09 PM
radar502's Avatar
radar502
Default 04-z a/c help
The A/C blows cold but when you go from the outside air to inside air it stays the same nothing changes don't know were to start looking ..Thanks for any help..
Old Jun 19, 2016 | 04:02 PM
radar502's Avatar
radar502
Any A/C people out there its hot in Houston and getting hotter.. ..Thanks
Old Jun 19, 2016 | 04:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That damper is VACUUM ACTUATED. If it isn't working, you may have other damper issues that you are not seeing. When you change the air vent path from LOWER to UPPER to DEFROST, does the air change its flow path or does it just blow out a random number of different levels??
Bill
Old Jun 19, 2016 | 04:14 PM
radar502's Avatar
radar502
I'll check ..Thanks..
Old Jun 19, 2016 | 04:27 PM
radar502's Avatar
radar502
I tried it .well it blows out of all the vents ,it will blow out the foot deal and will stop if you change it to stop blowing out at your foot deal other than that air come out all the vents.. It just blows ..This past winter in rebuilt the motor and had a Batt. problem so its been in and out and a PCM prop. so have been all over the thing but I try to make sue all is back were it should be but would be easy to have Brocken a vac line or left one off or it popped off . Don't know were to start looking for the right A/C lines that control the A/C . doors.. Thanks.. I thank it just a vac Problem ???
Old Jun 19, 2016 | 04:31 PM
radar502's Avatar
radar502
One more thing when you change from to foot back to upper it just not blowing out the floor it still blows out everywhere also so it does not stop blowing at the top so when you change it back to top it stops blowing at the foot ..
Old Jun 20, 2016 | 01:29 AM
BigGun's Avatar
BigGun
This link will answer a lot of your questions.
https://www.corvetteforum.com/forums...with-pics.html
Old Jun 20, 2016 | 09:09 AM
radar502's Avatar
radar502
This is what I needed thanks ,the 04 is 12 years old prop got a leek somewhere at lest I know were to start .Making 500 HP was easy in this LS-6 this looks like work but cheaper for sure and I have a set of gaskets if needed.. I drive with the window down arm out but the wife well we all know that deal , I'm hot ..Thanks. Going in ..
Old Jun 20, 2016 | 02:56 PM
radar502's Avatar
radar502
Am thinking if one of the VAC lines leaking or off then the motor has a VAC leek as well if the A/C ducks are pulling direct VAC off the manifold them I have VAC in the motor not just the A/C unless there is a check ball or something in the system incase this happens will not affect the running of the motor may not be that way , it runs good.. Just thinking out loud..
Old Jun 21, 2016 | 10:05 AM
radar502's Avatar
radar502
I read the deal and I see there is a check ball in the system cool . Prop. pull the intake were I can see what the heck is going on back there .I just seen this heat shield that goes under the intake 18-20 HP on the rollers dropped the temp on the intake 50% for $55.00 bucks why not be a good time to install.. Thanks for your help..
Old Jun 21, 2016 | 07:47 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PLAIN & SIMPLE!!!!!!!!!!
The VACUUM from "HERE"
Is NOT GETTING TO HERE:
I lengthened TENY TINY Vacuum Line behind the manifold so I wouldn't have that issue any longer:
From the vacuum reservoir,,,,,,,,, It goes to the vacuum controller where you (AT THIS TIME) have NO VACUUM!!! The solenoid cans are no longer being told (BY VACUUM) to open or close the damper/s and THUS,,,, AIR OUT OF ALL THE VENTS!!!!
NO! It wont effect the engine idle enough to notice without test equipment/ data logging
Old Jun 21, 2016 | 08:06 PM
Rob 02's Avatar
Rob 02
That is sticky material too.
Old Jun 21, 2016 | 08:16 PM
radar502's Avatar
radar502
Thanks ,for all the work I have done to this 04 this looks easy just track down the leek ,I have a vac tester . I might get lucky and something just popped off be the first time .. I got it from here .Thanks again for the info ...
To 04-z a/c help
