2004 having Seizures
Old Jun 27, 2016 | 07:54 PM
CorvetteKeithf's Avatar
CorvetteKeithf
Originally Posted by Bill Curlee
I agree... Use an OHM Meter and read the wire at pin D to the solenoid. See if its compromised. That wire has an inline fuse link and they can and sometimes do cause issues.
Bill
Couldn't get my multimeter to work on the wire... it was just showing 0.L when I put the one lead on the connector that shows battery voltage on the voltmeter, and the other lead on the starter terminal. (Slightly bent the pin trying to keep the lead on the alternator connector) But while I was messing with that, I cleaned off the two chassis grounds (didn't look bad) and I fiddled with the battery to starter wire that had some blackening at the terminal and the plastic covering the ring connector was chipped off. So I took the rest of the plastic off the ring connector, wire brushed it a little, and tightened the three nuts on the starter and put it all back together. Now it's doing it every start, throwing code p1637. Do you think me messing with the battery to starter wire set it off more meaning that's the problem?
Old Jun 27, 2016 | 07:59 PM
lionelhutz's Avatar
lionelhutz
Check the voltage at that wire, preferably with it running.
Old Jun 27, 2016 | 08:05 PM
CorvetteKeithf
Check voltage at which wire?
Old Jun 28, 2016 | 07:26 AM
lionelhutz's Avatar
lionelhutz
Seriously? The one that you've been told to check multiple times by 2 people.
Old Jun 28, 2016 | 12:19 PM
CorvetteKeithf
I was told to check a few wires. But I'm assuming you're talking about the one in the harness that is supposed to get battery voltage. Checked it today, and I couldn't get any kind of steady voltage. Bounced around from mV to .7v... rechecked the big power wire to make sure I was doing it right and it was steady at 12.3v. Used the same ground for both. So next step would be change the fusible link? I'm not exactly sure what it looks like and where I'd get one. Electronics aren't my strong point with cars, so I'm learning as much as I can as I go.
Old Jun 28, 2016 | 12:37 PM
lionelhutz's Avatar
lionelhutz
the fusible link is rather obvious. It's a piece about 6" long attached spliced onto the end of the wire. You can tell it's different then the rest of the wire.
You can check a fusible link by pulling on it. If it stretches then it's bad.
You can get a piece of fusible link at NAPA. You'll want a 20 gauge piece. You probably broke it completely when you worked on the starter terminals.
Get some double wall heatshrink tubing to cover the new connection splice you make.
Old Jun 28, 2016 | 12:41 PM
73Corvette's Avatar
73Corvette
Your doing GREAT... just ASK questions if you don't understand you have some really good guys helping you and they'll help you figure it out just do what they ask and don't be afraid to say I don't know what your saying and get more help... pics will help if possible
Check this link out...
https://www.corvetteforum.com/forums...ible-link.html
Old Jun 28, 2016 | 02:18 PM
CorvetteKeithf
Alright, let me asknow a weird question then. I found the fusible link I believe. Bought some replacement wire and was going to do it but it started raining. But i did notice that two wires seemed to be connected like an h pipe connects an exhaust. Is that normal and should I leave it alone? I'll try to take some pics when I can.
Old Jun 28, 2016 | 05:35 PM
CorvetteKeithf
We'll, I believe I fixed it!! No more charging system fault, no codes at all! So when I was looking at the two fusible links that were stuck together, I pulled them apart. Then tugged a little little bit on the smaller wire and it came straight out of the ring connector. Went to napa, whipped together the fix, and everything looks good now!
Culprit:
http://imgur.com/bMErU08
And if you look closely here, you can see where the two fusible links were stuck together:
http://imgur.com/2xdEAei
Old Jun 28, 2016 | 06:16 PM
73Corvette's Avatar
73Corvette
can't see the pics... good job though working thru and getting it figured out
Old Jun 28, 2016 | 08:14 PM
lionelhutz's Avatar
lionelhutz
Old Jun 29, 2016 | 09:14 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
First pic shows just a broken ring connector. Second pic shows a fuseable link at the top of the pic, but impossible to see damage.
Good job finding it.
Old Jun 29, 2016 | 11:15 AM
  #33
CorvetteKeithf
Yeah, first was the culprit, second if you look in the middle to the left of the brown wire, you can see the other link. They were stuck together pretty good
Old Jun 29, 2016 | 11:18 AM
  #34
73Corvette's Avatar
73Corvette
Dang it... when ya'll look at the pics this is all I see
Culprit:
Old Jun 29, 2016 | 12:48 PM
  #35
lionelhutz's Avatar
lionelhutz
It just looks like some of the glue from the heatshrink was holding them together. The double wall stuff has good glue in it. I only use it.
Old Jul 1, 2016 | 08:44 AM
  #36
73Corvette's Avatar
73Corvette
For future reference if someone is having similar issues this is a great link...
https://www.corvetteforum.com/forums...post1591319135
