HELP Code PO300
Old Jun 25, 2016 | 03:34 PM
Big_George_S's Avatar
Big_George_S
Originally Posted by Dave4Vettes
Well thanks to all who helped. I had removed the plugs and wires but when I installed the I reversed the wire but not the plug so to not make too many changes all at once but at your insistence I did go back today and switch and behold the miss moved. So a new plug later all is well. I all my many years I've had weak plug, ignition, etc. foul a plug but never one that wouldn't fire the timing light. Thanks again.
If you still have the old plug check for cracks. I had a 4-Runner that would throw the P03-- code every 3K I'd clear the code and change the plug but could find a small crack on the plug. Long story short head gasket was leaking and a small amount of rad-fluid was being sprayed on plug. Shaved and reinstalled heads, however it came back. For the cost I ended up getting a long block and junking the old motor. Its the wife's car and won't give it up.
Old Jun 26, 2016 | 07:16 AM
vettenuts's Avatar
vettenuts
Glad it worked out and was a simple fix in the end.
