need some help with my header install
Old Jun 22, 2016 | 01:33 PM
calbrit561's Avatar
calbrit561
Default need some help with my header install
SO i am going to install a set of obx headers on my car next week and i am finding some conflicting info on some things.
First what exhaust manifold gaskets do i use. I have found anywhere from using the old metal ones to using aftermarket non metal ones.
What should i do with my o2 sensors. I have read to either remove the rear and use them upfront or to just keep them the same.
If i keep them the same do i still need extensions and if i just use the rear in the front what do i need?
Its a 99 6sp vert if that matters
Thank you
Old Jun 23, 2016 | 04:04 AM
03redzo6's Avatar
03redzo6
I just installed them last weekend. I got a pair of 99 camaro z28 exhaust manifold gaskets from the chevy dealer. I used my rear o2 sensors for the front but I had to get some adapters. Btw, my rear o2 ports were already plugged, so I didn't have to worry about that.
Here is the adapter
http://www.racetronix.biz/itemdesc.a...LS1-O2&eq=&Tp=
Old Jun 23, 2016 | 06:23 AM
vettenuts's Avatar
vettenuts
Here is the adapter
Can't beat the GM gaskets for the headers, but the earlier gaskets have the ports required for the headers. If you move the rears, you need adapters. When I did this (don't currently run this setup) I bought a couple of high quality stainless clamps and put two longer bolts into the tunnel plate so I could mount the clamps. Then I used the clamps to take up the excess length so the wires wouldn't hit the headers.
Old Jun 23, 2016 | 05:31 PM
calbrit561's Avatar
calbrit561
I decided to just but the 18in extension for the front and use both. So what gaskets do I need because I see multiple part numbers for the c5 manifold gaskets from GM. You mentioned. One was better than the others do you know which one? Thanks
To need some help with my header install
