TPS system won't reprogram
Old Jun 27, 2016 | 10:04 AM
Inca32x's Avatar
Inca32x
Default TPS system won't reprogram
2002 corvette, went to 3 tire centers and they were unable to program the the tips. Used both the magnet tool and the scanner. Tires and tips sending units were replaced a year ago at Bell Tire in Michigan. Does this mean a computer problem?
Old Jun 27, 2016 | 10:27 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
A few QUESTIONS:
Have the sensors that you have in place now EVER FUNCTIONED?????
When you attempt to program them, does the TPS Function come up on the DIC???
Are the sensors that you have installed now the original sensors?
The actual place that you need to place the MAGNET is the spot on the RIM directly inboard of the stem.
IF,,,,,,,,,,,,,,,,,,,,,,,, You have OEM sensors, the programming tool will NOT program the sensor.
Old Jun 27, 2016 | 10:47 AM
Inca32x's Avatar
Inca32x
Originally Posted by Bill Curlee
A few QUESTIONS:
Sensors worked fine a year, new sensors were aftermarket that the tire store used. The DIC brought up the option to reprogram the tire monitoring system and then goes to the left front tire but the magnet over the valve stem or the scanner would start the process, even tried both with no success.
Old Jun 27, 2016 | 11:32 AM
Inca32x's Avatar
Inca32x
Originally Posted by 8VETTE7
It's TPMS if you mean the Tire Pressure Monitoring System and not tips or TPS. TPS is Throttle Positiion Sensor which has nothing to do with tire pressure.
You need to pull and post the codes. The codes that may help determine what has happened will be listed under B0 - RFA. If you have never pulled codes on your C5 before here is how:
https://www.youtube.com/watch?v=SviRjIsy9G4
OR
http://www.c5forum.com/ayc/dtcdic.php
Post ALL your codes including the H or C or HC that follow each 5 character code. List the codes under the sensor that they are shown under. ie 10 - PCM or 28 - TCS or 40 - BCM..... etc
Loss of communications or NO COMMS can prevent the system from properly working.
Also need to know what year your C5 is....
Was the proper technique used to try and program the TPMS?
https://www.youtube.com/watch?v=vOM96f3Iy6E
List of all codes: BCM c2100h, c2105hc, c2110hc, c2115c.
A6-SCM B2860H
A1-RDCM B2285H
60-IPC U1255H, U1060H, U1160h
A1-RDCM B2285H
Old Jun 27, 2016 | 12:45 PM
Inca32x's Avatar
Inca32x
The codes above that you listed under BCM are NOT BCM codes. THey are actually RFA (Remote Function Adapter) codes and they are telling you that none of the 4 TPMS are reporting. In order they are C2100=LF, C2105=RF, C2110=RR, and C2115=LR.
I have to wonder if the TPMS were EVER correctly programmed when you first had them installed.
Aftermarket TPMS can often be very tricky to get programmed to the C5. Some require letting air out of the tires, others require a standard programming device and still others require a proprietary programming device.
I suggest that, unless you can tell us what brand TPMS was used, your best solution is going to be to get the original seller to figure out what it takes to program the product they sold you.
That's all the codes in the system. They worked fine for a year.
Old Jun 27, 2016 | 02:06 PM
Inca32x's Avatar
Inca32x
The sensor ORANGE TPMS SensorSC3946, from orange electronics. Web site said they use same frequency as OEM.
Old Jun 27, 2016 | 02:09 PM
73Corvette's Avatar
73Corvette
I suggest you CLEAR the codes go for a drive then BEFORE you kill the car retrieve the codes again.... 1 of the 4 TPMS codes you had were c-codes which are current codes... 2 were HC codes, 1 was an H code or history code... regardless of when or how long they worked if they are not reporting in now then your probably needing them reprogrammed or replaced
Old Jun 27, 2016 | 03:01 PM
Inca32x's Avatar
Inca32x
Frequency is what the TPMS use to transmit to the receiver (RFA) and does not relate directly to the process needed to trip them to transmit. THe "trip" or force to transmit process for those sensors does NOT use a magnet. They use a change in air pressure. When the programming process is done the TPMS transmit an ID to the RFA that gets stored in the associated location that is being programmed ( ie LF, RF....etc) so the computer knows which wheel has what pressure to display in the DIC.
If I recall correctly you need to overfill the tire pressure (perhaps 40lbs) in each tire and then start the programming process in the C5 DIC. You need to move quickly to each tire as you have only about 45 seconds per wheel to get the TPMS in that wheel to program (honk the horn) by letting air out of the tire and then move to the next wheel. IF you fail to get any one of the 4 sensors to program within the alotted time you have to start all over again at the LF tire.
Once all 4TPMS have been successfully programmed you need to then adjust the tire pressures to the correct pressure.
Good luck with the programming proccess.
Thanks I will give it a shot.
Old Jun 27, 2016 | 10:24 PM
Good info on the aftermarket sensors and how to program them.
Old Jun 28, 2016 | 08:30 AM
Inca32x's Avatar
Inca32x
I was able to find the after market sensor information from the tire company and it is Orange Electronics and the sensor part number is SC3946 and is shown on their website also for 2001-2004 corvette. They have sensors for just about every vehicle. They are located in Ohio but neither phone number is working. I wanted to contact them to find out if they can be programmed with a. Magnet or do you need their scanner, which is what it looks like. Is anyone familiar with this outfit and a way to contact them?
By the way I cleared all the codes in DIS last night now when start the car I don't get the Service Tire pressure Monitoring System but the but the tire pressure shows LF 33 RF XXXX RR 33 LR XXX.
Old Jun 28, 2016 | 10:20 PM
Inca32x's Avatar
Inca32x
Once you clear the DTC's for the TPMS you will have to drive the car before they will reappear.
There are many threads on this Forum about the Orange brand TPMS. Most people that bought them for the C5 ended up returning them (or got stuck for the price of them) because they could NOT get them to program to the C5. The few that I saw that were successful on this Forum ended up letting air out as I described. A tedious process AIR....
Thanks for your thoughts. I am also wondering why all 4 sensors would suddenly quite working after 2 years when it appears to be no problems with the vehicle now or in the past. Should I be looking for an underlying problem .......
Old Jun 29, 2016 | 01:14 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
I bought 4 sensors for mine on Ebay years ago. Knock on wood, they've been wonderful. Not totally accurate, some are off about 7% which is 2psi, but knowing that and setting with a gauge, I know I'm safe. It would be nice if they were dead on accurate but for $150, what could I expect. (that's for 4, shipped). I put new batteries in my old ones and sold them on ebay. Netted about $120 over the battery and RTV cost so I was happy. Wasn't worth the time though. That's a fair amount of work doing them.
Mine program with a magnet just like stock, fyi. I'd never heard of any programming with air pressure change. Learned something new.
Old Jun 30, 2016 | 07:52 AM
Inca32x's Avatar
Inca32x
I would try to get them re-programmed. If they cannot be re-programmed you may have the answer to the problem.....
d
Tried programming by letting air from tire with magnets, did not work. However I no longer get the service tire pressure monitoring system or any other fault codes. I have been driving it for 2 days with many restarts and no warnings.
The DIC still shows LF 35 psi (all the time) RF XXXX, RR 33 (All the time), LR XXXX. The 35 and 33 have been the same through numerous reprogramming attempts but all tires have 30 psi.
I guess I will leave system alone as long as I don't get warning codes. Go figure.
Old Jun 30, 2016 | 02:00 PM
lonerider2002's Avatar
lonerider2002
I had the very same ones with the same outcome--worked for about a year then after changing the car battery no one could program them again(tire stores, dealer, me). Got tired of the flat tire warnings and replaced them with OEM Delcos--Tire shop just broke the beads far enough down to change them out-cost 40.00. I programed them w/a microwave magnet and they've been working fine since. Stay away from aftermarket TPS--it's not worth what u save.
Old Jun 30, 2016 | 04:37 PM
Inca32x's Avatar
Inca32x
I never did it to save money, thought the tire store manager new what he was specing because he was a Corvette guy.
Old Jun 30, 2016 | 08:21 PM
73Corvette's Avatar
73Corvette
Old Jul 4, 2016 | 09:15 AM
Inca32x's Avatar
Inca32x
Drove the car last night and low and behold the 2 front sensors are now working, the RR might be also But LR is stilXXXX. Strange.
To TPS system won't reprogram
Old Jul 4, 2016 | 09:17 PM
K-Spaz's Avatar
K-Spaz
That's some flaky sensors if they pick and choose the days they like to work.
Old Jul 4, 2016 | 09:53 PM
73Corvette's Avatar
73Corvette
I've had some employees that were like that... not for long though
Old Jul 7, 2016 | 09:40 AM
topdown01's Avatar
topdown01
d
I had something similar to your issue though different TPM manufacturer...not sure if what I did will work for you but maybe it will help...see post #15 in the following thread.
https://www.corvetteforum.com/forums...post1592436102
Hope this helps
