running rough
Old Jul 10, 2016 | 12:13 PM
painterman98's Avatar
painterman98
Default running rough
just finished installing complete exhaust. headers midpipe and mufflers. went for a test driveand it sounds great and ran perfect for about a mile then started running like it was on 4 cylinders. shut it off then started it back up and ran perfect for about the same distance. restarted in the garage and runs perfect then I just shut it off. any ideas on the cause. It threw no codes
Old Jul 10, 2016 | 12:28 PM
painterman98
I expected to see them
Old Jul 10, 2016 | 01:53 PM
KOZ's Avatar
KOZ
Sounds like you cracked a spark plug
Old Jul 10, 2016 | 02:01 PM
painterman98
a6-scm u1016h u1064h
a1-rdcm b2265h
ao-ldcm u1064h
40-bcm u1016h u1096h b2482hc b0507hc b0502hc
Old Jul 10, 2016 | 02:13 PM
KOZ's Avatar
KOZ
Pull and check all the plugs
None of those codes have anything to do with why your car is running rough
Old Jul 10, 2016 | 03:21 PM
ZigZag's Avatar
ZigZag
Originally Posted by 8VETTE7
You need to check the plugs and the wires since that was the most recent thing changed. Cracked plug or damaged wires most likely.
You added headers, when I did I ended up with two wires that got burnt through. Had to pull them all off to find the bad ones. My car was doing the exact same as you described.
Old Jul 10, 2016 | 03:26 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
You will also need a tune !!!!! http://www.eastcoastsupercharging.com/
Old Jul 10, 2016 | 04:30 PM
Nasbluec5's Avatar
Nasbluec5
Get some spark plug wire protectors. As already stated it sounds like cracked plugs. Put some fresh tr55s in it.
Old Jul 11, 2016 | 08:43 PM
painterman98
I changed the plugs and wires. started it up and it runs perfect for a minute or two then rough as can be. I turned it off and restarted it and it runs perfect for a minute or two. so i turn it off and restart immediatly and it runs great so i just shut it off. i have no clue whats going on
Old Jul 12, 2016 | 09:14 AM
painterman98
I cleared all the codes. started it after a minute it began running rough . I left it running and there are no codes. the starter is good for sure. Its hard to tell about the other grounds but they appear to be ok
Old Jul 12, 2016 | 09:38 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had the exact same issue after a header install. All looked fine BUT,,, once you dug a little deeper, THIS is what you could fine:
You do NOT have to have a TUNE but,,,,,,,, you will NOT get all the HP/Tq that is on the table from what the header install has to offer and you will loose a little fuel economy until it tuned.
When the engine starts running rough, LOOK at the Check Engine Light. See if it is FLASHING. If its flashing, that indicates a cylinder or multiple cylinder misfires. IF,,,,, you pull up the DTCs "WITHOUT turning off the ignition, you will or SHOULD see a P-300 (misfire DTC).
Bill
Old Jul 12, 2016 | 09:44 AM
DetroitPlac's Avatar
DetroitPlac
When I installed my headers, I replaced the plugs and wires. It was running about as you described, and I started to panic. So I pulled all the wires off and sure enough, I managed to crack one of the brand new spark plugs. Replaced it and it was fine. It's absolutely worth double checking that they're all ok, and heat socks on the wires are a great idea as previously mentioned.
Old Jul 12, 2016 | 09:56 AM
painterman98
I put on new exhaust because I was having trouble with leaks and rattles. It is tuned for headers. I replaced the new plugs and wires with even newer plugs and wires. what I don`t get is why it runs perfect for a short time then runs bad I shut it off and immediatly start it and it runs perfect again. no codes or check engine light
Old Jul 12, 2016 | 10:14 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Do you have these wires in the right spot ???
Old Jul 13, 2016 | 09:11 PM
painterman98
I fixed it. I had the o2 sensors reversed. I didn`t know they had to be in a specific spot. it was easier to run the wires the other way . all is well. thanks for the help and concern
Old Jul 13, 2016 | 09:19 PM
73Corvette's Avatar
73Corvette
Thank YOU for posting what your issue was and how you fixed it... nice find!
To running rough
