C5 Z06 Emissions system
I bought a C5 Z06 years back that has a lot of mods.
Not to my knowledge, the "exhaust emission system" seems to have been removed to get more power, but i ended up recently moving to CA and want to put it back on so avoid trouble with cops/smog etc.
I took my car over to a local mechanic who sent me this pic of the parts i need (highlighted yellow). I'm having a terrible time finding these parts online other than part 19 - the smog pump which i easily can find for about $50 on ebay. Also Part 5 seems to be easily had for about 20 each (need 2 apparently).
Any advice on how to get the rest of the parts?
Stealership quoted $1100+!
The A. I. R. (Air Injection Reaction) system which consist of an electric air pump, some pluming to each bank and A.I.R. Check Valves. If you are going to functionally use that system, purchase NEW A.I.R. Check Valves.
The PCV system and if you have a 2001-2004 C5, It consist of this:
You also have a Fuel System Evaporative Emissions vacuum connection on the drivers side of the intake manifold that goes to a Solenoid and then to the fire wall pluming that goes to the rear of the car (fuel Tank).
If you post a WANT TO BUY in the C5 parts for sale/wanted section, I'm SURE that there will be someone with ALL these parts.
Another option is contact Forum Member VETTENUTS. He own a C5 Salvage Yard and has ALL the parts that you would ever need. Good People with great parts!
Bill
I'll see if i can get in contact with Vettenuts.
Headers? Not allowed in CA unless CARB certified. Very few mods allowed in CA as most items do not pass CARB.
P.S. Too bad on the parts needed, I think I discarded all mine finally just a couple months back.
It will be cheaper in the long run and he will be able to get you all the parts that will fit your year C5 as a system. i.e. The exhaust manifolds and the mid pipe need to come off the same year C5 as a system. Manifolds off a 98 will NOT fit the mid pipe off of a 2000. LS6 manifolds will not fit a LS1 mid pipe. Some exhaust systems require PRE or PUP cats. Getting the wrong system may cause you to FLUNK Visual Tech Inspect.
Bill
Marc
marc@vettenuts.net
But it is a gamble.
My car is registered in WA but I drive it in CA... /shrug - I would never pass emissions here. Def a gamble... but never been messed with yet by the police,
