P0300 Code..
Old Jul 13, 2016 | 02:28 PM
DA1984VETTE's Avatar
DA1984VETTE
Default Check Engine Light Flashing..P0300 Code..
Driving today and parked to eat no troubles. Got ready to leave the car had a rough idle, running sluggish or not hitting on all cylinders. The check engine light did come on and I ran a diagnostic check while driving and got the P0300 Code. I know it is an engine misfire according to what I read, but any direction to help solve the problem would be helpful. I really don't want to take it to a dealership to have it checked out if possible. Basically the car runs like crap.
Old Jul 14, 2016 | 12:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Without knowing the age and condition of the entire secondary ignition system (plugs & wires) I would have to recommend that you start there!
Install NEW GM Irridium sparkplugs gapped at 0.040" and purchase and install some new GM Performance RED Wires!
The above recommended replacement parts are the BEST BANG FOR THE BUCK and will last for another 75,000 miles!
You can also just inspect what you have. Look for loose wires on the plugs and coil towers. They tend to pop off sometimes. Also make sure that the wires are not damaged insulation wise. If there an OEM wire, You can OHM out the wires. The OEM wires should measure approx. 250 ohms to 750 ohms. OEM Wires reading in the high 1000s ohm range are BAD.
Start there and let us know what you have..
Gene Culley (Forum Sponsor) has the wires for around $65.
Bill
Bill
Old Jul 14, 2016 | 12:58 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hi DA1984VETTE,
I am sorry to hear you’re experiencing these concerns with your Corvette and understand how this may be frustrating. I see that you are seeking advice from other forum members, however, please don’t hesitate to send us a private message if you would like to visit your dealership. We would be happy to provide an additional layer of support during that process!
Best,
Julie C
Chevrolet Customer Care
Old Jul 26, 2016 | 09:01 PM
DA1984VETTE
Bill
Bill
Put new wires and plugs and it is still running bad, but not as bad. Put on MSD wires and installed NGK TR55, the plugs were gapped at .057 checked them all with a gauge. Are these plugs gapped to much or should I just get the AC plugs and install them. The plugs came with the wires. Forgot about Gene or I would have got them there. No codes were thrown this time. I believe the plugs and wires were originals.
Old Jul 27, 2016 | 12:39 AM
gimp's Avatar
gimp
I believe that 0.040 is recommended for most cars. They used to come with 0.060 but it was too big a gap and some cars did not run smoothly.
If it still runs bad, I'd do all the other basics:
- Clean / replace engine air filter
- Replace fuel filter
- Run techron concentrate through the fuel system
- Clean MAF sensor
- Replace PCV valve
- Check that the idle air controller works by tapping it as it runs and observing whether there is any change in idle speed
- Make sure your AC is off
- Clean your throttle body
- Look/listen for any vacuum leaks (also, with the car idling and parking brake on, does the idle change as you depress the brakes? this is indicative of vacuum leak or failing/failed brake booster)
This is always a good place to start for rough idle / rough running situations.
Old Jul 27, 2016 | 01:32 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
- Clean MAF sensor
- Replace PCV valve
My exact response was WHY 0.057" ?????????????
Go 0.040!
EXACTLY!
Bill
Old Jul 27, 2016 | 02:09 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I agree plugs and wires would be my 1st and most common fix------
That being said if that does not cure the misfire there are other things that can cause a P0300 code---- A faulty injector would throw a whole new code so I would not suspect injectors However I have seen cars especially those approaching 10 years of age where a clogged or bad CAT will throw a misfire code---Typically when a cat fails the car will feel extremely down on power So if the plugs and wires don't cure it---Have your cats checked for backpressure at most any reputable muffler shop
Old Jul 27, 2016 | 07:19 AM
vettenuts's Avatar
vettenuts
So it ran fine until you came out of a restaurant and then it ran bad? Did it happen immediately or was it a mile or two down the road? Had you recently bought fuel?
If it were mine, I think I might disconnect the battery to clear the fuel trims and then try again and see what happens.
Old Jul 27, 2016 | 07:36 PM
DA1984VETTE
I bought fuel a week or so before this happened. I always buy Shell V-Power 93 Octane, but that doesn't mean I didn't get a bad batch of fuel. I probably shouldn't say it ran fine until I came out, but I have noticed it didn't run as well as it should be running and this was before the fuel fill up. I got the code and the check engine light about a mile or two down the road.
Old Jul 27, 2016 | 07:38 PM
DA1984VETTE
- Clean MAF sensor
- Replace PCV valve
Thanks for the suggestions, but I have done everyting above except the idle air controller and replacing the PCV valve.
Old Jul 28, 2016 | 10:20 PM
DA1984VETTE
Put in new plugs today gapped at .040 still no change. No new codes are showing up. It acts like it is not getting enough fuel, that is just my opinion. It just feels like I am towing a load and doesn't have enough power to pull it. At my wits end with it...
Old Jul 29, 2016 | 11:13 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IDLE AIR CONTROLER ????????????????????????? Your LS engine does NOT have an idle air controller. The PCM adjust the Throttle blade to control idle.
Pull off ONE plug wire at a time and see what that does to the engine idle.
If you disconnect a wire and it does little or nothing, that cylinder is NOT working properly.
The ones that cause the engine to falter and run WORSE are taking most of the load.
Old Jul 29, 2016 | 06:49 PM
DA1984VETTE
Thanks for all the help and suggestions guys I really do appreciate it. I haven't been able to drive it for a couple of weeks because of the problem or problems so I just gave up and it's now at Bud's (Forum Sponsor) in Celina to be checked out. Again thanks for all the help..
Old Jul 29, 2016 | 09:59 PM
gimp's Avatar
gimp
My bad, bill. I get used to copy and pasting that advice for all sorts of cars
Old Aug 2, 2016 | 06:01 PM
DA1984VETTE
Just heard from Bud's about my car. It seems there was no compression on #2 cylinder. They found the intake valve spring was broken. They said the valve spring is not a GM spring and wanted a little info on my car. I advised them the guy I bought it from said it had the Z06 hot cam in it. I asked him why the change was made and he advised it was done before I got it. So I would "assume" that they changed the valve springs when they did the cam swap. So they are going to do more research on the spring to see what kind it is and get it replaced. Hopefully this fixes the problem..
Old Aug 2, 2016 | 06:10 PM
gimp's Avatar
gimp
Damn, no compression on a cylinder, that will do it. Good luck!
If one spring is broken... being the slightly paranoid person I am, I'd probably just replace all of them instead of just the one.
Old Aug 2, 2016 | 08:35 PM
joe Villarreal's Avatar
joe Villarreal
U can check which plugs are firing with a timing light
by clipping the holder to each wire and pressing the timing light button each time it fires the light will flash if it doesnt flash check wire and plugs on this cylinder.....
Old Aug 3, 2016 | 04:41 PM
enoniam's Avatar
enoniam
I'd replace all of the springs as well.
Old Aug 4, 2016 | 08:01 PM
DA1984VETTE
I got her back today and all is well. She runs like she used to... I want to thank everyone for the suggestions as they were much appreciated and I did try most of the suggestions before getting fed up and took her to Bud's. If this happens again and I DON'T drop a valve I will as someone suggested go ahead and put all new springs in. Funds were a little tight this time around to do that. Again a big THANK YOU to everyone who responded...
To P0300 Code..
