New the the forum. Just bought my first corvette. A 2000 c5 5.7 auto. Went to clean it, washed the engine bay with a "engine degreaser" at the local car wash, really washed around the water pump etc. soon as I started it up it made a god awful noise. I shut it off, let it sit. Re started it, everything good, drove it all day and that night I noticed it getting hot. The coolant temp gauge was going from 200-250 up and down every few minutes. Twice it even went to 260 in the red, i pulled over and shut it off let it cool. Started it up temp started going down then back up and repeat. I checked the radiator and nothing it blocking it, could this maybe be a thermostat? Maybe a water pump? I'm letting everyone this cool down right now before I get into it. Gonna start by checked coolant level and etc. worries me because I had a Duramax before this and it done the same thing, it was head gaskets..
Since you washed the engine, you may have water in the electrical connections which could be giving you the erratic readings. Did the car actually boil over or was it just the gage indicating an over temp condition? You might take compressed air and blow out various connectors and let things dry out.
It's always risky pressure washing engines with all the electrical stuff there. I would check to make sure the cooling fan is coming on, you may have accidently unplugged it.
I don't know if a non working fan would cause the gage to fluctuate but it certainly wouldn't hurt to check. Also try turning on the heater when the engine is up to temp. Do you get heat. If yes, thermostat and water pump are working. Does the engine temp drop and stay in more normal ranges? If yes, could be pointing to the radiator.
I wash my engine a couple times a year. I don't use a pressure washer. I just use a garden hose. I use compressed air to dry things off a bit before starting the car.
UPDATE: the coolant was low. I added some and attempted to cycle it threw until it got dark. When I left the car the tank was full. Now this morning looking at it it was almost empty. I tested the thermostat yesterday too and it opened around boiling point (my thermometer only went to 200). I filled the tank back up, drive it on Ramps and now under the car it's leaking antifreeze from the leaf spring (right under the water pump) I'm thinking it may be a water pump, I just got the car and the water pump looks really new. Is there a weap hole? If so where at? Should I pressure test the cooling system? And BTW when the car was warmed up yesterday I had no heat at all, the fans work though
Check all of your hoses carefully, under the throttle body, around the thermostat housing, look on the underside of hoses with a mirror, you may have sliced a hose with the pressure washer, they get pretty brittle with age and heat.
