Center Brake light??
Old Sep 12, 2002 | 04:13 PM
ROCKETCOWBOY's Avatar
ROCKETCOWBOY
Default HELP, Center Brake light??
99 coupe center (the small one) brake light is not working. How do I get to it to take it out? Do I have to buy the complete lamp or is there a bulb I can replace? The dealership said I needed the complete lamp for $105.00 but they were not sure and would look further into it. Any help here?? Thanks again!
[Modified by ROCKETCOWBOY, 3:23 PM 9/12/2002]
Old Sep 12, 2002 | 04:41 PM
curvete's Avatar
curvete
Default Re: HELP, Center Brake light?? (ROCKETCOWBOY)
The CHMSL (center high mount stop light) light does not have bulbs, its LED illuminated. You probably will be stuck with having to buy the light from Chevy if its really gone out. However, LEDs are very reliable and don't often go out. I'd be suspicious of the wiring or a fuse.
Old Sep 12, 2002 | 04:48 PM
ROCKETCOWBOY
Default Re: HELP, Center Brake light?? (curvete)
Wiring or fuse? How would I go about getting to the light to check the wiring? Where else would I check the wiring? Where is the fuse at to check it? Is there any way to check the LED to see if it is good? Any help would be great!! Thanks again!
Old Sep 12, 2002 | 04:58 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I am sure the bulb can be replaced, let me go check. Maybe not, I forgot the car is not here. I need the red lens and I must purchase the whole unit. Pt # 10253893 $93.16
[Modified by wallstAL, 1:01 PM 9/12/2002]
mj3793's Avatar
mj3793
YOU CAN GET TO IT BY REMOVING THE RIGHT OR LEFT TAIL LIGHT , CHECK THE PLUGS GOING IN THE BACK , I HAD THE SAME PROBLEM AND ALL IT WAS A LOSS PLUG .
Old Sep 12, 2002 | 05:25 PM
GasmanZR1's Avatar
GasmanZR1
Default Re: HELP, Center Brake light?? (mj3793)
I also had the same problem, and it turned out to be just disconnected from the wiring harness. Another way to get at it, is to remove the backup light assembly. There are 4 screws that hold it into place. Just unscrew them and the whole assembly comes off. You might want to have another person help you, so they can hold the assembly while you disconnect the 2 reverse light bulbs. Then you can reach up and feel to see if it is connected or not. Hope this helps.
Michael
Old Sep 13, 2002 | 09:33 AM
ROCKETCOWBOY
Default Re: HELP, Center Brake light?? (Manny Jagerfeld)
Thank you for your help Manny and everyone else!! I will this stuff out and go from there!!
To Center Brake light??
