Help with trouble code O2 sensor
Old Sep 12, 2002 | 06:08 PM
hpcubed's Avatar
hpcubed
Default Help with trouble code O2 sensor
When I am cruizing on the freeway at about 1500 rpm I get the trouble code P1057 which, according to the code definitions that someone posted on this forum, means " Heated O2 sensor circuit low voltage bank 2 sensor 2.
Is this the rear O2 sensor behind the cats? Supposedly Mike turned them off when he tuned my car.
If not, what is the issue -- sensor needs replacement?
Old Sep 12, 2002 | 06:25 PM
SFVetteman's Avatar
SFVetteman
Default Re: Help with trouble code O2 sensor (hpcubed)
Bank 2, Sensor 2 refers to the right rear O2 sensor. You might want to get back to Mike about this.
