MMS 223 heads n custom Cam
For those wondering why we decided to go with the speed density tune it was to eliminate any restriction in the intake path. By removing the mass air we are removing a big restriction on the intake path and given this combo best opportunity to make power and get as close to or over 500rwhp from this LS1.
Enjoy the vid from last night.
https://www.facebook.com/CorvettesofPasadena/videos/1388705787888306/
For the High Definition vid go to my Facebook page to view it.
Facebooks page name is C.O.P Tuning Solutions
https://www.facebook.com/Corvettesof...8705787888306/
just bear in mind it's like having an electronic carb, so you'll want to keep a close eye on the AFR and adjust it a few times throughout the year, unless you live in the most moderate possible climate/area.
Here is the specs:
MMS 223 Heads milled to 60cc, hand finished by MamoMotorsports
Custom cam 227/232 on 113 with .613/.610 lift
stock Rockers with Trunion kit upgrade
Ls7 Lifters
Melling high pressure oil pump
Ls2 water pump (did not have to grind on TB or water pump with this setup)
Fast 102 Intake
NW 102 TB
Ls2 fuel rails
52lbs injectors
255 fuel pump
Lg SuperPro 1 7/8 Long tube headers, X pipe no cats, Borla Stinger Catback
Speed Density Tune (no MAF) to avoid restriction on the CAI
Monster stage 3 clutch with steel flywheel
My goal was to get as close to 500rwhp as possible...
I should be getting to the Dyno sometime this week if possible, and have some results....
I want to give thanks to my good friend
@Regorih383 from C.O.P Tuning Solutions for Tuning the car..
For the HD quality visit my FB page : C.O.P Tuning Solutions
