Help!!!
Old Sep 15, 2016 | 09:58 AM
boberschmidt's Avatar
boberschmidt
4th Gear
Default Help!!!
I have a 1998 C5 that the battery ran down and I jumped it off. It ran a short time idling and died and won't restart. I have P0601 and p1518 codes and I sent the Pcm off for repairs with no luck. I have seen previous posts with this problem but no fixes posted. Please help.
Old Sep 15, 2016 | 01:09 PM
mmartinez's Avatar
mmartinez
Please clarify what no restart means, does it crank over but doesn't fire up or doesn't crank. I would recommend having the battery load tested before you do anything else, as your problem started with the battery being run down, hope this helps solve your problem.
Old Sep 15, 2016 | 04:44 PM
gimp's Avatar
gimp
If you jumped it and it died again, I'd look at the alternator.
Old Sep 18, 2016 | 07:28 AM
Greg_E's Avatar
Greg_E
Apparently this is a fairly common problem with 1998's.
https://www.corvetteforum.com/forums...n-t-start.html
See post #5
BTW when you title your post something like "Help!!!" many people are not going to bother reading it. Also, If others search the archives because they are having a similar problem the search engine is probably not going to find your thread.
When you get the problem resolved please post what was done to resolve it.
Old Sep 30, 2016 | 09:12 AM
Greg_E's Avatar
Greg_E
Any progress?
To Help!!!
