so engine is out!!
Old Sep 15, 2016 | 11:13 PM
momo20's Avatar
momo20
Default so engine is out!!
So ended up pulling my motor out of my 2003 Z06 due to sound i was not really all the comfortable with, come to find out it was a broken ringland on lucky number 7. Luckily in my case it did not do any damage to my cylinder wall at all thank god!!
So been calling around to several machine shop's in my area and talking to several friends and have found a shop to do my work
My original plan was to just replace that one piston with one from brother's 2002 LS1 motor that he has and have new ring's installed and reseal the motor and call it a day...Well after talking with people and reading i have come to the term's that is a cheap fix and in the end prob. won't last long ..
So now i am going to go forged internal's to handle the supercharger output....
I just need to know what brand you all recommend and if I can use my stock rod's or if I need to upgrade those as well ??
my block number
this one has me stumped as to what it can mean?? its location is front of the block behind the PS
and i took all my fenders/bumper/hood off just to make sure they did not get damaged in the process of all of this...
as you can see i took the engine out of the top...for me it was easy..total time was about 4 hours and that is removing the drive line as well
Old Sep 15, 2016 | 11:39 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Did you find the other piece of piston ?? Make sure it's not hiding in the heads or intake or guess what ???? Just in case your reusing them or selling them to someone else !!!!
Old Sep 15, 2016 | 11:46 PM
momo20's Avatar
momo20
no very little damage to the head...almost looks like it got sucked out the exhaust valve and right into the high flow cats...passenger side was in almost perfect shape ..how ever the drivers side the high flow car was all bent up...i am reusing them..they will get looked over at the machine shop as well
Old Sep 16, 2016 | 12:20 AM
Forcedvert's Avatar
Forcedvert
Funny how the reflection on cylinder wall looks like a piece is missing (of cylinder wall).
Good luck
Old Sep 16, 2016 | 12:32 AM
momo20's Avatar
momo20
Good luck
haha i did not see that till you pointed it out..lol...it does..in the picture but i can assure you that is just the piston and no the cylinder wall
Old Sep 16, 2016 | 01:49 AM
StingrayRebel's Avatar
StingrayRebel
sucks to see it was a ringland but look how clean those pistons are, gotta love meth... looks like evidence of detonation though all over the piston and it finally had enough... hard to tell but I can't see anything on the piston next to it in your pic
Old Sep 16, 2016 | 09:20 AM
momo20's Avatar
momo20
i can get more pics of the rest of the engine later today when i get home from work.
Old Sep 16, 2016 | 03:55 PM
gimp's Avatar
gimp
Damn! How much boost are/were you running?
Old Sep 16, 2016 | 06:00 PM
momo20's Avatar
momo20
Boost the car is set up for 9 lbs ...but no steam ports and I am not running meth yet..Pistons were really not that dirty to start with ...it's a common problem with #7 it's important now that I know if anyone is boosted or making more power then stock to make sure you have steam ports on the rear heads..had I those and meth kit I probably would not even had to post any of this
Old Sep 16, 2016 | 06:31 PM
StingrayRebel
I thought you were already running meth, those pistons are damn clean for not using it
Old Sep 17, 2016 | 11:31 AM
momo20's Avatar
momo20
so onto my questions??? what aftermarket forged piston's does everyone use??
any one know what the 5 zero's mean?
can i use my stock rod's or should i go with aftermarket rods?
Old Sep 17, 2016 | 01:32 PM
StingrayRebel
talk it over with your builder, there are tons of different options depending on your budget... I would definitely do a set of rods and pistons and leave the crank alone and the block would be good to around 900-950, much more than that and the crank will start flexing... the weak link in the rods is the bolts and the cracked capped design is not all that great either... rpm is usually what kills the stock rod bolts so if you rev higher than stock redline or like to rap it out a lot I would definitely take care of the rods while the block is apart... personally I would rather spend a little more now and save the headache later... I would also do a set of arp head studs to help keep the heads from lifting due to the added cylinder pressure
Old Sep 18, 2016 | 04:23 PM
sean.b's Avatar
sean.b
thats the single most luckiest thing ive ever seen in a blown engine, literally. go buy me a lottery ticket
thanks for the build log. i was debating pulling mine out of the top this winter because my lift isnt at my house anymore. 4 hours doesnt sound too bad.
Old Sep 18, 2016 | 08:16 PM
momo20's Avatar
momo20
lol right..and this is my 3rd time pulling the drive line out..once a few year's ago to have my transmission built..second time on a 2002 coupe vette so he could have his transmission rebuilt..and now...so once you know how to do it ..its pretty easy really..
Old Sep 19, 2016 | 02:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you are going to run a lot of boost, your ring gaps need to be a bit wider than a stock engine.. That could have contributed to your ring land issue..
I recommend adding a steam cross over to the rear of the engine. Its easy to do. Use the 2001-2004 front cross over and just flip it 180 deg. Run a rubber hose to the front and T it in.
That's what I did..
Old Sep 20, 2016 | 11:17 PM
momo20's Avatar
momo20
That's what I did..
i actually have your write up saved on my pc...i can't find a OEM 4 port steam pipe so your way was the next best way to do this..and seems like it work really well...
Old Sep 21, 2016 | 08:39 AM
LoneStarFRC's Avatar
LoneStarFRC
Several different companies make steam port fittings with -4AN male fittings. Buy this kit or get the fittings and make your own hoses.
http://www.superchevy.com/how-to/eng...vent-line-kit/
https://www.summitracing.com/parts/tfs-306s0601
http://www.affordable-fuel-injection...th-an-adapter/
Wegner makes these with female 1/8" npt threads
http://paceperformance.com/i-1031131...pt-outlet.html
LOTS of possibilities.
To so engine is out!!
Old Sep 21, 2016 | 09:05 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Weisco pistons...
Old Sep 22, 2016 | 10:38 PM
momo20's Avatar
momo20
Originally Posted by Capthuff
Weisco pistons...
any reason why ?
just curious is all..trying to get as much info as i can
Old Sep 22, 2016 | 11:57 PM
silver408z's Avatar
silver408z
Like mentioned, talk to your engine builder. Sometimes they have their own preferences and work with certain parts better than others. I would personally do rods while you are in there. They are not that expensive and you will be able to turn up the boost later if you wanted.
