LS6 on 2002 C5 base
Old Oct 12, 2016 | 05:01 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Originally Posted by Skyhawk23
Pounder,
Thanks. I will have to take a look this weekend and report back.
You can also flip down your glove box lid and on the inside should be the sticker with all the RPO codes for your car as it was built. If you see a G90 code you would have the 3:15 upgrade. If not, you have the 2:73. That's if the original owner did not change it out. Checking the tag on the diff will verify.
Old Oct 12, 2016 | 05:56 PM
Skyhawk23's Avatar
Skyhawk23
Alxltd1,
Thanks for the the info. From the way it look on your tag then you don't have a 3.15? am I right?
Old Oct 12, 2016 | 06:05 PM
alxltd1's Avatar
alxltd1
Alxltd1,
On the pictured tag that is correct, but that is not my tag. I have a 2000 coupe with 6-speed manual and a 3:42 diff. My glove box is filled with the relays, switches, and controller for my nitrous set up.
Old Oct 13, 2016 | 05:56 PM
Skyhawk23's Avatar
Skyhawk23
Alxltd1,
Alxltd1,
Checked the tag no G90. So I am just a plan 2.73 LOL
Old Oct 13, 2016 | 06:01 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Alxltd1,
you would be amazed at the difference 3.42 would make, I see a ton of them on E-bay but I would go with Vettenuts in case it's not up to your standards (think he (Marc) would take care of you)!!
http://www.vettenuts.net/ Also you want a 3 rib dif. !~!!
Old Oct 14, 2016 | 12:24 PM
Skyhawk23's Avatar
Skyhawk23
Pounder,
You mention the 3 ribs diff.? Is there any other kind to get?
Old Oct 14, 2016 | 12:36 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Pounder,
the other is 2 rib //// 3 rib stronger !!
Old Oct 14, 2016 | 12:55 PM
nsogiba's Avatar
nsogiba
https://www.corvetteforum.com/forums...ferential.html
Old Oct 14, 2016 | 01:45 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
that is a good deal !!!! wished I could find 4.10's that cheap !!!!
Old Oct 14, 2016 | 01:52 PM
nsogiba's Avatar
nsogiba
You and me both brother. I'm still on the hunt for a used 4.10 diff. I think my only option is sending out my 3.42s to be built with a new 4.10 ring and pinion for something like $1200+
Old Oct 14, 2016 | 02:04 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
from I found 1200 would be on the low end, still pricey, I'm still thinking of buying the gears and doing it myself ???
Old Oct 14, 2016 | 02:18 PM
Skyhawk23's Avatar
Skyhawk23
Pounder,
Sorry for more dumb questions, so by looking at the diff. I should see the 3 ribs? Or how else I can tell from looking at it?
Old Oct 14, 2016 | 02:25 PM
  #33
Pounder's Avatar
Pounder
1/4 mile/AutoX
Pounder,
There are no dumb questions, take a look at the link from post #28 and notice the three ribs on top of the dif. first pic.
Old Oct 14, 2016 | 02:31 PM
  #34
Skyhawk23's Avatar
Skyhawk23
Pounder,
You rock.
