Parking Brake Question
Old Oct 30, 2016 | 08:40 AM
  #41
dabit23's Avatar
dabit23
Mine too was inoperable. After removal, cleaning, and relube of the handle mechanism it works as a parking brake.
Old Oct 31, 2016 | 12:11 AM
  #42
garebear's Avatar
garebear
Originally Posted by leadfoot4
I was never very impressed with the holding ability of my parking brake, so like many "week-end wrenches', I decided to fix it. This, of course, ended up with the brake working in an even less effective manner.
Earlier this week, I bought the proper sized drum brake measuring tool, as illustrated in the FSM, and two days ago, I set about re-adjusting the brake shoes. Initially, I found that I had way too much clearance between the p-brake shoes and the inside of the rotor, so I adjusted it to the specified 0.015" clearance. I then put everything back together, happily thinking I was good to go.
Not so fast.....as the p-brake will now at least hold the car from rolling down the driveway, if I put the car in gear, and give it even a little bit of gas, the engine will still overcome the p-brake's holding ability.
Is this right?
I always say "if it ain't broke, fix it 'till it is"...
Old Oct 31, 2016 | 06:53 AM
  #43
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Whereas I always say, "Use it as a learning experience", and the second time around, you'll have it fixed correctly............
