Harmonic Balancer replacement + Others???
Old Oct 14, 2016 | 06:37 PM
Zoidman's Avatar
Zoidman
Default Harmonic Balancer replacement + Others???
Hi Guys!
I just got a call from my dealership saying that I need to replace the harmonic balancer on my 2000 C5. It's an automatic with about 92,000 miles. I agree with the dealership that the balancer should likely be replaced. I've heard some chirping noises from the engine... and already replaced all the belts and tensioners trying to eliminate the chirp.
The dealership wants about 850$ to do the replacement.. ouch
I've read that when you are that far into the engine, it is an excellent time to preventively replace some other parts such as
- Timing Chain
- Oil pump
- Camshaft??
Anything else you would recommend replacing? Is there any reason the cam would wear, and would need to be replace it?
Thanks!!
Last edited by Zoidman; Oct 14, 2016 at 08:02 PM. Reason: Forgot to mention mileage
Old Oct 14, 2016 | 08:16 PM
Smoken1's Avatar
Smoken1
- Timing Chain
- Oil pump
- Camshaft??
This all depends on your goals, Chain and pump yes.. As for harmonic balancer don't get a stock one b/c it will fail again
Old Oct 14, 2016 | 08:34 PM
Zoidman's Avatar
Zoidman
My goals are to try and not get back into this area again, cause it's a lot of expensive labor! The car is a daily driver and I'm satisfied with the performance, but reliability is very important.
Can you recommend a balancer?
I've been looking at the ACDelco 12560115 for about 84$.
And the ARP 2342503 Stud Kit for around 34$ more.
Old Oct 14, 2016 | 08:49 PM
Smoken1's Avatar
Smoken1
I would look at the Powerbond alot of Ppl use them as a replacement... As for the replacement bolt yes ARP is better
Old Oct 14, 2016 | 09:06 PM
Zoidman's Avatar
Zoidman
Turns out that Powerbond is now a Dayco brand!
Anyway, I found the PB1117N
It seems to sell for about the same price (85$) at O'Reilly or a couple places online.
I am also considering getting a replacement timing kit (gears and chains) rather than just the chain. The KT3-4194S kit by Sealed Power seems to fit the bill.
Any thoughts?
Old Oct 14, 2016 | 09:21 PM
Smoken1's Avatar
Smoken1
Pm sent
Old Oct 15, 2016 | 07:45 AM
vettenuts's Avatar
vettenuts
I would think you could find a Corvette specialty shop in your area that would do the work. I would just go with the GM timing kit if I were in your position, it is made by Cloyes and is actually a pretty good setup.
Old Oct 15, 2016 | 09:55 AM
Zoidman's Avatar
Zoidman
I called up the specialty shop in my area, and they were pretty expensive! Quoted me 50$ higher to do the balancer swap than the Chevy dealer where it is at =/
On the plus side, the specialty shop is more like to be willing to use parts I bring in, than a dealership would be. I haven't had a chance yet to ask the dealership if they'd even be willing to to use my parts...
I've read some debates over high volume and high pressure oil pumps. I had an issue with my car on some mountain roads last year, where the oil pressure dropped to a mere 2 PSI after pushing it hard. I've been suspicious of my oil pump ever since.
This is the only reason I'd consider swapping the oil pump out to a high pressure version.
I'm fine with OEM spec part swaps on pretty much everything, unless there is some aftermarket part which my promise longer term reliability.
Old Oct 15, 2016 | 12:12 PM
vettenuts's Avatar
vettenuts
Pushing it hard is likely a drain back issue and not the pump itself. That's one reason they add extra oil for events like that, the oil stays on the head and doesn't drain back fast enough. High volume pump will only make it worse.
Old Oct 16, 2016 | 03:04 PM
Chicago1's Avatar
Chicago1
Sound about right for the labor. Any chance of doing it yourself? i did mine and a few others and its not that bad. And yes do the chain, cam etc etc since you are right there.
Old Oct 16, 2016 | 06:04 PM
Ls2gtoowner's Avatar
Ls2gtoowner
This.
I would do an oil pump as well.
I run an innovater west crank pulley but that might be a tad expensive for your setup. They are very pretty though!
Old Oct 16, 2016 | 07:03 PM
Chicago1's Avatar
Chicago1
A powerbond will be fine for his needs.
Old Oct 24, 2016 | 06:37 PM
twizted91gt's Avatar
twizted91gt
$850 for the labor?? Thats extremely excessive. Most performance shops will have a full cam install package kit that will include all the labor/parts for $1800 or thereabouts. Youll get your pulley issue fixed and another 40-50 rwhp while everything is apart.
Old Nov 2, 2016 | 09:49 PM
Chicago1's Avatar
Chicago1
A cam kit is about 700 or cheaper lets say 800...So your at 1000-1100 for labor according to you...
Old Nov 3, 2016 | 05:57 AM
twizted91gt
Right im sure you also remember the set of gm gaskets, oil/fluid change, new plugs and oh yea $400-500 complete dyno tune that comes with that package.
Old Nov 3, 2016 | 05:19 PM
maj75's Avatar
maj75
Try at least $2800 for that package in South Florida.
Old Nov 3, 2016 | 06:31 PM
twizted91gt
God I thought ny prices were high.....
There are at least 2 sponsor shops off the top of my head on here that offer a full setup tuned for ~$1800
Thats the reason i suggested the OP go that route, just another option rather than dropping half the cost of a full cam swap on an oem crank pulley replacement.
To Harmonic Balancer replacement + Others???
Old Nov 3, 2016 | 07:14 PM
American Heritage's Avatar
American Heritage
Supporting Vendor
Is your squeaking sound only at startup or all the time?
If its only at start up or when cold check to see if you water pump is leaking. Often times a slightly leaking water pump will cause the belt to chirp when first started or when cold.
http://www.americanheritageperformance.com/
Old Nov 4, 2016 | 09:37 AM
KBL's Avatar
KBL
Default Pully replacement
Hi Guys!
- Timing Chain
- Oil pump
- Camshaft??
Thanks!!
I had to replace mine because of the typical corvette pulley wobble. I got tired of throwing belts. Changed the pulley and as you said I put in a Lingenfelter cam, roller lifters, c-6 heads, racing oil pump, high volume water pump and other stuff. After removing everything I took the block out and had a machineshop install the cam and heads. Heads up make sure the machine shop will guarantee the work mine didn't because they were performance parts. I have a neighbor who is a mechanic so this mid-life crises wasn't so bad. The car is absolutely deadly now. You may want to be careful in that the motor could run a little warmer than you care to have it so I had to pop for a radiator and fan set.
Old Nov 4, 2016 | 01:01 PM
LiteraCola's Avatar
LiteraCola
Just yesterday I called my local dealership to price out a balancer/crank seal install... The truth is, a friend of mine asked if I wanted to do his for him but wasn't sure what was a fair price. I said I was interested but wanted to see what the dealer would charge. The dealer quoted close to $1600 and would only install the GM balancer. Completely and utterly ridiculous. Ask me again why I never take my car to the dealer.
