P1416 tuning question
Old Oct 23, 2016 | 11:48 AM
Mastertvtech's Avatar
Mastertvtech
Default P1416 tuning question
Replaced the valve 2 years (16K miles) ago and the code is now back. If I have it tuned out will I have any issues with inspection when they plug in?
Also do you leave the tube in place or cap it off near the alternator?
Old Oct 24, 2016 | 10:38 AM
Gordy M's Avatar
Gordy M
There was an alternate fix on a video a few years ago.
https://www.corvetteforum.com/forums...1416-code.html
Old Oct 25, 2016 | 05:38 PM
Mastertvtech
I would rather never have to deal with it again. I don't want any issues at inspection time.
I also couldn't find any info of the negatives to doing this.
Old Oct 25, 2016 | 05:47 PM
Smoken1's Avatar
Smoken1
I have never had an issue after I deleted my AIR system
Edit: Yes you can tune out the code and still pass emissions tests
Old Oct 26, 2016 | 01:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Before you get tooo carried away deleting stuff, I would carefully inspect the rubber hoses, piping and fittings that deal with BANK 2 A.I.R. stuff.
Directly below the master cylinder is a metal SS "Y" pipe and rubber hoses. Seen that/those hoses ROT and cause the same code. The AIR fitting FLANGE directly on the exhaust manifold has a small fiber gasket that can deteriorate and leak air and give the same DTCs. Take it off and inspect. Make sure that flange is sealed and tight.
Take that BANK 2 fitting off the intake manifold, Cold start the engine and see if you have a GOOD stream of fresh air from the A.I.R. supply pipe.
If NOT, something is wrong. Figure it out. YES, that NEW check valve can be the issue. If the Rubber diaphragm inside the check valve is stuck shut or the air flow path is compromised that bank will not flow the proper volume of air required to pass the test for that side O2 sensor.
To P1416 tuning question
