Headlight issue (gear was replaced)
Old Oct 25, 2016 | 05:42 AM
Predaderp's Avatar
Predaderp
2nd Gear
Default Headlight issue (gear was replaced)
New to the forum and have an issue with my headlight.
About 2 months ago I had the factory, stripped hear replaced with a brass one by the dealership since I didn't have the tools to fix it at the time. After a few days I noticed the headlight shuts unusually hard, almost slams down and is about .5cm from being shut all the way. I didn't think anything of it until recently. Now it sometimes doesn't come up unless I manually shut it all the way. Also, it started making grinding sounds after it goes up or down for a few seconds. Anyone else have this issue after replacing the gears?
Old Oct 25, 2016 | 06:01 PM
Crusty 1's Avatar
Crusty 1
Sounds like they did not get the flat spots on the main shaft back in the same position as when it was removed, before they put the arm back on. When you take the metal piece out of the plastic gear it is important to make sure the location of the flat spots on the shaft are put back in the same position.
Old Oct 25, 2016 | 06:05 PM
Crusty 1's Avatar
Crusty 1
I just did mine last Saturday, but I used the aluminum gear kits off of e-bay. 2 aluminum gears were cheaper than one brass gear, Additionally the kit came with grease, gloves, sticks for grease application, seals for the old type of actuator and brackets for the new type and lastly some dielectric grease for the headlight connections.
Old Oct 25, 2016 | 09:59 PM
Predaderp's Avatar
Predaderp
2nd Gear
So the headlight wasn't "top dead center" when they set it?
Old Oct 26, 2016 | 02:09 PM
Crusty 1's Avatar
Crusty 1
I marked my flat spots with a sharpie before disassembly. That way I could position the gear with the flat spots in the same location as disassembly. They are youtube videos that show what I am talking about.
Old Oct 26, 2016 | 02:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are TWO white PLASTIC STOPS on the head light assembly. That's where the head light STOPS against when it raises and lowers.
If those plastic stops are damaged or missing, it can cause opening and shutting issues.
The grinding is not normal. I would first inspect the stops and see if they are there and not damaged. You can purchase new plastic stops and install them on the housing assy.
BC
Old Oct 26, 2016 | 09:22 PM
Mickeyrx70's Avatar
Mickeyrx70
Originally Posted by 8VETTE7
Here is a link to a thread that has pics of the bump stops that Bill speaks to . 4 per headlight, ie 2 for stopping the open and 2 for stopping the close. I'm certain Bill meant to say 2 PAIR of plastic stops
https://www.corvetteforum.com/forums...ght-shake.html
I only have 3 each side on my '02. I've never been able to find the mounting post for the 4th bumper stop. I know where it's supposed to be, it's just not there.
Old Oct 26, 2016 | 10:01 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
As an aside, the stops do not need to appear damaged for them to cause issues. I don't think they will cause the grinding the OP is talking about, but I'll defer that to the folks who've seen more of this.
My stops had barely a dimple on them where they had rested for years. I don't think the surface of the plastic had compressed .030", yet the lights failed to raise and lower.
Old Oct 29, 2016 | 02:23 AM
striper's Avatar
striper
Rodney Dickman, who makes the brass gears, also makes plastic stops out if a better material than the factory. I use them in my car and they don't wear out. They are fairly cheap too.
To Headlight issue (gear was replaced)
