EBCM removal
Old Nov 4, 2016 | 09:55 AM
Vistance's Avatar
Vistance
Default EBCM removal
[Deleted]
Old Nov 4, 2016 | 10:08 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There's SIX torx bit screws that secure the EBTCM to the Brake Pressure Modulator Valve (BPMV) module. Remove the main connector, remove the pump motor connector under the module and the six fasteners. The module has a thin rubber gasket and that gasket may STICK the two together.
There is ZERO liquid or fluid inside the module. It should be DRY inside!
NOTE and a WARNING!!!!!!!!!!!!!!!!!!!!!!!!!!!
The BPMV has METAL SPOOLS that protrude out of the module and into COILS that are attached to the circuit board inside the EBTCM. If you pry the EBTCM side ways or UP/DOWN, you will break the coils off the module.
The module should easily separate or pop straight off for removal.
If the fasteners that you remove don't screw into the BPMV, you are not removing the correct fasteners!!!
WHAT errors, issues or DTCs are you having that makes you THINK that the module is bad. Please read and post the DTCs using the DIC during an active IGNITION CYCLE. (before you turn off the engine!)
BC
Old Nov 4, 2016 | 10:20 AM
Vistance's Avatar
Vistance
[Deleted]
Old Nov 4, 2016 | 12:57 PM
Vistance's Avatar
Vistance
[Deleted]
Old Nov 4, 2016 | 01:50 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Ignition key & ignition switch
The KEY portion of the ignition switch and the SWITCH portion are entirely TWO DIFFERENT parts.
I can change out the key portion (KEY CYLINDER/VATS SENSOR) and insert the new one into your same old SWITCH part of the module.
SO,, please don't ASSUME that the ignition switch part is NEW unless you have some documentation from the stealership that states that they installed a new IGNITION SWITCH and a NEW Key Lock CYLINDER
BC
Old Nov 4, 2016 | 02:18 PM
Vistance's Avatar
Vistance
[Deleted]
Old Nov 4, 2016 | 04:36 PM
Vistance's Avatar
Vistance
[Deleted]
Old Nov 4, 2016 | 11:05 PM
StingrayRebel's Avatar
StingrayRebel
I had the same code pop up a couple of years ago and in my case it was a few broken solder joints on the relay inside the ebcm... all I had to do was open the ebcm up and resolder the relay and it has worked fine since then... if I were you I would open it up and look at the relay joints and try resoldering them, worst case scenario you might have to end up replacing the $5 relay inside the ebcm but all in all it's an easy job that you can do yourself and save a chunk of money and time... here is a link that explains the process in depth but it appears a lot of the pics are now missing, https://www.corvetteforum.com/forums...r-fleabay.html
Old Nov 5, 2016 | 12:53 AM
Vistance's Avatar
Vistance
[Deleted]
Old Nov 5, 2016 | 08:15 AM
apex26's Avatar
apex26
Default it's not bad, just be gentle
My car just had this problem--at 25k miles. After some basic checks and cleaning all 6 grounds, I had the Chevy dealer do their diagnostic tool for $99, which confirmed the EBCM was bad. It's easier to get at some of the recessed screws from the bottom, especially if you're old like me and your hands don't work as well as they used to. Just pay attention to how the bail clip fits, so you can just snap it back on, no fuss. I had to use different tools for different bolts, due to the recess and tight access to some. But, I have huge oil lines that were in the way from the bottom, it's not bad really.
Old Nov 5, 2016 | 10:58 AM
StingrayRebel
Originally Posted by Vistance
As for the EBCM, soldering is no biggie for me so I would consider doing that. But depending on the level of PITA to get the thing out/put back in, if a new battery (after ensuring the old one is truly bad) does not resolve and the other troubleshooting steps don't help, I'll probably just send the thing in to ABSFixer. Here's hoping I won't need to do that.
regardless if you send it out or fix it yourself you're gonna have to take it out anyway, it's an easy job so if you have the means you might as well save yourself the money and time... you could take an afternoon to get it done and back on the road or wait a week or more for shipping back and forth plus the time it takes them to fix it... I removed the top 2 bolts from up top and got the rest from the bottom and removed/installed it from the bottom as well since it was easier for me to see and maneuver it that way
Old Nov 5, 2016 | 05:32 PM
Vistance's Avatar
Vistance
[Deleted]
Old Nov 7, 2016 | 07:41 PM
Vistance's Avatar
Vistance
[Deleted]
Old Nov 8, 2016 | 01:09 AM
WildRide357's Avatar
WildRide357
Wow just wow great info on this thread Gentleman, thanks! I'm sporting the same codes as OP. Gonna get to the bottom of my problem!
Old Nov 9, 2016 | 06:46 AM
Brackets's Avatar
Brackets
do those stupid interior lights ever go off? I sat there for probably 10 minutes and they never dimmed. Every other car I've owned they automatically click off after about a minute.
Clue?
Old Nov 9, 2016 | 10:20 AM
Vistance's Avatar
Vistance
[Deleted]
Old Nov 9, 2016 | 10:34 PM
Brackets's Avatar
Brackets
It does seem a little odd and an excessively long time although I can't comment for sure on the 'Vette as I don't have one right now. Currently I'm driving an '05 CTS V but I don't think my R.A.P. stays active for more than about 5 minutes.
Old Nov 10, 2016 | 09:04 AM
Vistance's Avatar
Vistance
[Deleted]
To EBCM removal
