Parasitic Draw
Old Jan 4, 2017 | 04:22 PM
2ndvett01's Avatar
2ndvett01
Default Parasitic Draw
Where do you place multimeter probes to check for electrical draw with engine off?
Old Jan 4, 2017 | 04:44 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
pos. cable hooked to the batt. your tester leads between the unhooked neg. cable and the neg. batt. terminal.
Old Jan 4, 2017 | 08:12 PM
Ron C!'s Avatar
Ron C!
Glove box light staying on is very common. Something to check.
Old Jan 5, 2017 | 12:08 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just so you don't have to search through 590 replies:
BC
Old Jun 4, 2018 | 09:28 PM
Amazing1's Avatar
Amazing1
Default Multimeter 101 Help Please
My question pertains to the correct settings on the multimeter. The neighbor I borrowed one from wasn't sure which setting to use. Can someone help please.
I used the one which has a "wavy line" above a "mA" with another large script "A" below the other letters. There is also another setting with the
same wavy line above what looks like a italic looking "u" next to an "A"
Anyone?
When I turned on the multimeter it stayed on 0.02 and didn't change
no matter how I moved around the two connection points to insure a
good connection. Is it possible that there is something wrong with the
multimeter, or am I missing doing something right?
Old Jun 4, 2018 | 11:07 PM
Moved to C5 Tech.
To Parasitic Draw
