Need tutorial on rebulding C5 diff.
Old Jan 10, 2017 | 11:54 PM
BURL's Avatar
BURL
Default Need tutorial on rebulding C5 diff.
I recently posted a message about doing a full C5 rebuild using C6 parts. Bill Curlee sent me a link to a great tutorial o how to do the whole rebuild. However I've changed my mind and only want to do the upgrade that a novice can do - I don't want to attempt a full, clearance setting rebuild.
I found where Bill also referenced to a poster about the more minor upgrade but after I Private Messaged him I didn't get a response. Here is a couple of sentences from that post:
I have a LIST of recommended post to read on this very topic that I will attach later tonight . It discusses installing all new C6 ZO6 output shafts, clutch packs and newly improved Heavy Duty Beleview clutch pack springs.
These improvements can EASILY be accomplished by the Do It Yourselfer and DOES NOT require any special differential alignment/gear set up special equipment stuff!
OK, so I have Z06 3.42, Hoosier carbon fiber clutch packs, hardened long and short shafts and I need to find a write up that lists what else I can easily replace (no full rebuild) with stronger parts and hopefully a tutorial to show how.
Sorry for the long post and thanks in advance.
Old Jan 11, 2017 | 09:28 AM
midnight01's Avatar
midnight01
I would seriously consider getting a pro to install it. 1 wrong torque setting or improper gauging of the packs and you might detonate the entire rear. UNLESS yo are familiar with the process just make sure you buy feeler gauges, and have all the tools needed, and here is the link to the GM rebuild per another forum member
https://drive.google.com/file/d/0B5g...=1&hl=en&pli=1
Old Jan 11, 2017 | 10:35 AM
BURL's Avatar
BURL
Default Diff upgrade
Have read the upgrade (better shafts, clutches, etc) is relatively easy compared to a full tear down and rebuild. Been working on Chevys for years just not familiar with Corvettes. Have feeler gauges and about every common hand tool known to man. I don't think much in the way of special tools is supposed to be needed for the parts upgrade. Don't have Corvette special tools but can get any that are needed.
I just need a list of stronger bolt=in parts (have the shafts and clutches)and a post or tutorial of how it is done. I'm gonna double post at this point and put a copy of this in the Super Charged / turbo'd section. Those guys don't leave anything in one piece very long.
Thanks for any help anyone can provide.
Old Jan 11, 2017 | 10:47 AM
midnight01's Avatar
midnight01
Either way, good luck. The shafts don't seem to be too difficult to replace and/or remove. It's the pumpkin that needs the special tools. I have done gear replacements myself, but this was in the older rear ends like the 10 bolts and the 12 bolts. It was not hard but certainly not easy either. Now with these rears they threw all kinds of monkey wrenches. Whatever you do take your time and triple check your work.
Old Jan 11, 2017 | 02:49 PM
voda1's Avatar
voda1
Here is one: https://www.corvetteforum.com/forums...and-right.html
Old Jan 15, 2017 | 12:13 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Replacing the clutch packs/washers/output shafts is a pretty straight forward process.
This tool is a big help getting the stuff apart.
Have fun and good luck with your project.
Old Jan 15, 2017 | 12:25 PM
RonSSNova's Avatar
RonSSNova
The link voda posted is excellent. Print it out and go for it.
No gear setup involved.
The tool Capthuff shows is nice but not necessary.
A bearing press is needed though. Just use some sort of small round shaft that will press on the part. That's all I did.
Its rather a fun project actually.
ron
Old Jan 15, 2017 | 12:33 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
The first time I separated a diff apart, I used a piece of 2x4 that I cut a notch in and a crow bar as a press.
Where there's a will, there's a way.
Old Jan 16, 2017 | 05:57 PM
BURL's Avatar
BURL
Would you say this is the only special tool needed for the upgrade (shafts, clutches, bellville washers)?
Old Jan 16, 2017 | 06:07 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Well, - a torque wrench and a press would be helpful. But no other real specialty tools needed.
Old Jan 16, 2017 | 06:22 PM
cbell3186's Avatar
cbell3186
I just did this job and I used that special tool and a hydraulic press from harbor freight. A torque wrench is needed also. I used a wrench on the diff to hold the diff case bolts while I torqued to 41 ft/lbs.
Old Jan 16, 2017 | 06:36 PM
BURL's Avatar
BURL
Seem to know your stuff about these diffs. To restate I have C5 z06 diff, 300m replacement shafts, Hoosier carbon clutch packs,( still looking for/deciding on Bellville washers). I see that some people replace one gear on one side of the diff with a C6 gear, Should I be doing this? Since I am ot using the C6 shafts will that gear fit with my aftermarket 300M shafts or will I need to keep the C5 Z06 gear?
Thanks in advance for any help.
Old Jan 16, 2017 | 07:47 PM
BURL's Avatar
BURL
Default Diff tools
Have all that stuff. Just wondered about the special tools. Thanks
Old Jan 17, 2017 | 09:16 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
In the C5 diff, the shaft that most often breaks, and as a result, most often gets replaced, is a one piece shaft/spider gear.
Replacing it with the C6 shaft - or a 300m shaft from your favorite vendor, requires also purchasing a new spider gear for that shaft.
It's all direct fit, as the dimensions and splines are the same. In fact, I don't even think you can buy the original one piece shaft/gear anymore.
Old Jan 17, 2017 | 10:21 PM
Re-opened this thread at the OP's request.
Closed the thread in C5 Forced Induction/Nitrous.
To Need tutorial on rebulding C5 diff.
