Test gauge cluster
Old Feb 2, 2017 | 10:55 PM
chasboy's Avatar
chasboy
Oldtimer
Default Test gauge cluster
Is the a way to power up the gauge cluster lighting on a work bench?
Popular Reply
Feb 3, 2017, 11:18 AM
6speedsteve's Avatar
6speedsteve
I had a power unit built that I just plug into mine. I just checked & my dimmer also works.
Old Feb 3, 2017 | 12:56 AM
SilverC54me's Avatar
SilverC54me
Default C5 IPC connector pin out
Here is the connector end view pin out for the IPC. It will require a couple of power connections to make the lighting come on. There will not be the ability to dim/brighten the lighting. I believe that the dimming function is controlled through the BCM.
Gary
File Type: pdf
Old Feb 3, 2017 | 10:15 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are TWO types of gage cluster lighting on the C5 cluster.
- First: Are the incandescent bulbs that back light all the little SYMBOLS on the face of the gages. The CEL light is a diode LED type of bulb.
-Second: The gage face Numbers and gage needles are lighted by TWO black light florescent tubes on either side of the cluster. There is a dedicated 12 VDC to 700 VAC Inverter on the back of the IPC that powers those tubes.
Are your black light florescent tubes lighted when you turn on the driving or headlights???? Is the DIMMER SWITCH properly adjusted to allow the lights to be seen????
Bill
Old Feb 3, 2017 | 11:18 AM
6speedsteve
Attachment 48060023
Attachment 48060024
Old Feb 3, 2017 | 11:23 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
VERY NICE!
Old Feb 3, 2017 | 12:42 PM
chasboy's Avatar
chasboy
Oldtimer
Yes, everything is working, I merely wanted to power it up because I've changed the button bulbs to red led and was curious about adding a red glow to the center part of the cluster. I don't want to change any of the stock bits, and I don't want to compromise the gauge readability. I have a couple of individual red LED's. I want to see if they can be "judiciously" placed somewhere to accomplish this.
Old Feb 4, 2017 | 12:10 PM
mygt350's Avatar
mygt350
Cruising
Very nice job!
Couple questions.
1. Is pin out for 2002 same as 1999?
2. If A2 is powered, would that illuminate highbeam indicator?
3. If A15 and A16 were powered, would that illuminate both turn signal indicators?
4. What determines message on LED?
5. If B2 powered up, will that illuminate drivers seat belt indicator?
Can you identify which pins are ground and which are powered? From angle of pic, I can't see it clearly.
Martin
Last edited by mygt350; Feb 4, 2017 at 12:15 PM. Reason: Added request to identify which pins were used and better pic of connector.
Old Feb 4, 2017 | 05:09 PM
chasboy's Avatar
chasboy
Oldtimer
Open up the PDF posted earlier. I tried fooling around with a 9v battery and test leads, but got no response. I do have a portable emergency start battery for a 12v supply, but I don't want to fry anything.
Old Feb 4, 2017 | 06:25 PM
6speedsteve
Originally Posted by mygt350
Very nice job!
Couple questions.
Martin
I can only give you the connections I am using, I do know we had one other power hookup that after a couple of minutes the whole cluster would flash possibly due to too much input? not sure, once that was pulled all was OK.
Red is A13 A14 B17
Black is B8 B13 B15
Chime works
Dimmer works
DIC functions work, have to continually reset or the REDUCED comes up.
Old Feb 5, 2017 | 06:59 PM
chasboy's Avatar
chasboy
Oldtimer
Thanks, think I'm going to shelve this "idea"
Old Apr 10, 2020 | 02:23 AM
mcm95403's Avatar
mcm95403
chasboy and 6speedsteve, THANK YOU SIRS! This is wonderful. I swear, the C5 forum is the best part of this forum, SO MUCH help here!
Old Jan 7, 2023 | 08:23 PM
IronMaidens2.0's Avatar
IronMaidens2.0
I know this is an old thread but can anyone tell me if you can check mileage this way also .
Old Jan 8, 2023 | 01:41 AM
SilverC54me
Yes, you can get to all the DIC display info like this so long as you have the DIC buttons.
Gary
Old Jan 13, 2023 | 03:12 PM
IronMaidens2.0
Originally Posted by SilverC54me
Yes, you can get to all the DIC display info like this so long as you have the DIC buttons. Gary
I think this is a long shot but we're would I get the male plug he is using in the picture .
Old Jan 28, 2024 | 05:42 PM
stuckina8track's Avatar
stuckina8track
1st Gear
Default Connector for cluster
https://batee.com/products/90-05-wir...-connector-kit
Batee.com has a Harness Kit, get a 12v supply from Ebay, I got a 12v dc 5amp
To Test gauge cluster
