Speed-o-meter
Old Feb 12, 2017 | 11:05 PM
C5 Newb's Avatar
C5 Newb
Default Speed-o-meter
About a month ago my speedometer quit working and when the car was shut off and restarted it worked fine.
Last week it quit working again and now restarting does nothing.
Although the speedometer is not working the cruise control works and displays your speed when you set it.
Any ideas what to start with in diagnosing the problem?
I did a search but didn't find anything related.
Old Feb 12, 2017 | 11:31 PM
Rob 02's Avatar
Rob 02
Any BCM codes?
Old Feb 13, 2017 | 11:56 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have a HUD, does it show the correct speeds??
BC
Old Feb 14, 2017 | 01:09 AM
C5 Newb's Avatar
C5 Newb
I don't have a HUD, I didn't think to check for codes, I will first thing in the morning
Old May 11, 2017 | 10:29 PM
THOM_7's Avatar
THOM_7
5th Gear
I have the exact same issue in my 99, restarting the car fixed it the first couple of times, then last week it went out and hasnt started back again...no new codes and I dont have a HUD..anyone have any ideas where to start looking for the issue? Possibly related, my fuel gauge went out around the same time the speedo started acting up. I know this is the sending unit on one of the tanks I just havent got to it working on it yet.
Old May 11, 2017 | 10:58 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any thing wrong with the fuel level system is PCM monitored and will usually set a DTC. Clear all the DTCs and see what comes back. Get a meter out and see if all the supply voltages & Grounds are there.
Bill
Here is your shematic:
Old May 12, 2017 | 10:45 AM
ApexerER's Avatar
ApexerER
The stepper motor that drives the speedo needle probably crapped out...
Old May 13, 2017 | 07:11 AM
SG Lou's Avatar
SG Lou
I was just thinking the same thing....GM was notorious for having crap stepper motors in the late 90's early 2000's.
I had to replace all 6 stepper motors in my 03 Silverado. While i was at it I did a LED swap for the dash lights as well.
And you'll noticed the Oil Pressure is pegged....C5's aren't the only ones with oil sending unit problems.... It's been replaced since this picture was taken !
Old May 15, 2017 | 12:32 AM
C5 Newb's Avatar
C5 Newb
The car isn't throwing any codes and I do not have a HUD. When I set the cruise it tells the speed in the DIC area
Sometimes it works and sometimes it doesn't. If it don't most times shutting it down and restarting makes it work.
Old May 15, 2017 | 02:30 AM
romandian's Avatar
romandian
Bill
bill, what year is that for?
Old May 19, 2017 | 03:54 PM
C5 Newb's Avatar
C5 Newb
Bill
Thanks Bill for the wiring schematic. I am a fair mechanic but suck at electrical stuff and I am afraid I don't even know what to look for on the diagram. I am not good with wiring diagrams...
Old May 20, 2017 | 07:48 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!!!!! I here you. Sometime we just have to start with the BASICS. Look at the fuse and you will see that it is supplied by something called "HOT in ON & Start"
That means it is supplied by a 12 VDC supplied by the IGNITION SWITCH. Our C5 Ignition Switchs are widely known to be a source of voltage output problems. The contacts inside get burnt and worn and the voltage out of the switcn can be less than 12 VDC. Our modules DO NOT like less than adeaquate supply voltages.
Some module have dual supply voltage and the OTHER voltage is a dirrect battery feed "Hot at ALL TIMES"
On top of the fuses are two small slots. Use a DC Volt meter and read each slot to chassis or battery ground with the ignition switch ON. Especially measure it when the gages are whacked out. If it is less than full battery voltage, the switch could be causing issues with the gages.
Bill
Old May 21, 2017 | 02:13 PM
C5 Newb's Avatar
C5 Newb
Bill
Thanks Bill, I will start there.
Old May 21, 2017 | 02:38 PM
C5 Newb's Avatar
C5 Newb
I had a few stepper motors so I changed the speedometer one yesterday for the hell of it and it still doesn't work. so the must be elsewhere. I will try Bills suggestion today.
Old May 21, 2017 | 03:27 PM
UstaB-GS549's Avatar
UstaB-GS549
A possibility is the VSS. It also controls reverse lockout, automatic door locking, HUD and cruise control. All of those stopped working at the same time my speedometer quit. My speedometer would work intermittently.
Old May 21, 2017 | 06:50 PM
Maddhammer's Avatar
Maddhammer
1st Gear
I bought my 97 c5 a month ago, speedometer has never worked, starting working today when I turned off traction control.
Old May 21, 2017 | 07:08 PM
C5 Newb's Avatar
C5 Newb
Bill
Bill, I just want to make sure we are on the same page. Your a corvette expert and I am lost so I am not saying your wrong here I just want to make sure we are understanding each other.
Everything works in the car BUT the speedometer when driving.
Speedometer DOES go through it's full sweep when you turn the key ON.
I don't have HUD.
When your driving and set the cruise control the speed shows in the LCD display.
Cruise control works.
Reverse lockout works.
Just wanted to clarify what is working and what isn't for everyone who may be following this including you BIll.
Old May 21, 2017 | 07:10 PM
C5 Newb's Avatar
C5 Newb
Bill
I don't mean to sound retarded here but are you saying to check fuse # 13 or all the fuses ?
Old May 21, 2017 | 07:59 PM
C5 Newb's Avatar
C5 Newb
Ok. I checked for codes even though the check engine light wasn't on. The LCD display always shows ABS, Traction control and active handling so I always clear those.
But when I checked for codes this time it had a bunch.
A couple are known problems with the BPMV having a stalled motor but Not sure if any of the others have anything to do with the speedometer.
Here they all are.....
B2253 Key Cylinder Switch Circuit - H ?? For some reason you can pull the key and it keeps on running, I did this the other day to show my brother, probably what cause this...
B2723 PASS-Key Detection Circuit - H ?? Same as above??
C1242 BPMV Pump Motor Ground Circuit Open -H C - Known issue
C1243 BPMV Pump Motor Stalled - H C - known issue
C1247 Brake Pressure Differential Switch Activated - H - Brake bleeding the other day?
P0420 Catalyst System Low Efficiency Bank 1 - H C - Cat going bad?
P0654 Engine Speed Output Circuit - H - ??? Cluster out the other day?
P0804 Skip Shift Lamp Control Circuit - H - Bulb out of circuit board?? (New bulbs ordered)
U1096 Loss of Communications with IPC - H - From removal of gauge cluster??
To Speed-o-meter
