DeWitts New Coolant
Old Feb 28, 2017 | 12:16 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Default DeWitts New Coolant
DeWitts Pre-mixed Coolant is specifically formulated to be a premium, all-season coolant/antifreeze for high performance automotive engines. It contains a patented low silicate corrosion protection package that prevents rust and corrosion and is specifically engineered to protect materials used in modern performance engines. DeWitts High Performance Coolant offers a more advanced additive package than standard “green” coolants and maintains better thermal conductivity and heat transfer than propylene glycol (PG) based coolants. The advanced additive package contains special anti-foam agents to reduce water pump cavitation and increase cooling capacity. DeWitts High Performance Coolant meets GM 1899M, Ford ESE-M97B-44-A, and Chrysler MS7170 specifications and is compatible with all nationally distributed coolants and liquid coolant additives. System protection is maintained from -34°F to +265°F when used with a 15lb. radiator
Product Page
Use promo code 301promo for a 15% discount
Old Feb 28, 2017 | 07:27 AM
vettenuts's Avatar
vettenuts
Is this similar to other coolants that require a full drain, i.e., they don't mix well or will it mix with Dexcool should there be some residual in the system?
Old Feb 28, 2017 | 07:41 AM
runner140*'s Avatar
runner140*
Excellent question...
Old Feb 28, 2017 | 09:30 AM
Patches's Avatar
Patches
I could just read it on the zoomed-in pic on the website but you might want to indicate it is a gallon jug somewhere on that page.
Old Feb 28, 2017 | 05:40 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
We do recommend a flush and a full system fill. Some Residual is nothing to loose any sleep over however I would not directly mix any two types of coolant, ours included.
To DeWitts New Coolant
