Clutch assist spring
Old Feb 28, 2017 | 10:23 AM
SVT_Z06's Avatar
SVT_Z06
Default Clutch assist spring
How many of you guys have taken out your clutch assist spring? I did it when I had pedal sticking issues and it seemed to help without it.
Just curious.
Old Feb 28, 2017 | 01:23 PM
radar502's Avatar
radar502
I took mine out at the same time I replaced the master ,I have no sticking pedal now did , but don't know if the spring being removed helped or replacing the master did it anyway I like it way better with the spring out ..
Old Feb 28, 2017 | 03:13 PM
Cheesecake 07's Avatar
Cheesecake 07
Just curious.
Mine just broke last night. Yanked it out...only difference I could tell is my cruise control dont work w/o the spring(the spring forces the pedal up the last few mm's, off the sensor).
Im putting a new one in.
Old Feb 28, 2017 | 06:28 PM
tungstenfoot's Avatar
tungstenfoot
I had sticking pedal after a couple 1/4 mile runs so I removed clutch spring to see if it would help while i ordered a new one. I've yet to install the new one nearly a year later. i'd say its slightly less prone to stick without it. But removing it certainly won't prevent sticky pedal altogether.
To Clutch assist spring
