Headlight Door Not Opening
Old Feb 28, 2017 | 12:09 PM
parrottp's Avatar
parrottp
From: Smithtown New York/Naples Florida/Flint Twp. Michigan
Default Headlight Door Not Opening
The headlight doors on my 2001 vert with 72,000mi on it will not open when the headlights come on. The headlight door control module is receiving the on signal from the multi function turn signal switch when in the headlight on position and the off signal when in the off position with twilight off. When twilight is on the HDCM receives both the on and off signal from the MFTS. The HDCM sends out a signal on both the up and down terminals for both doors at all times. I have two questions. Shouldn't the HDCM only send out a signal for up when lights are on and down when off and should the twilight setting send both on and off signals at the same time? Ignition switch has been rebuilt and grounds have been cleaned. There are only two codes that reoccur every time they are cleared. They are BO-RFA 1000H and 1064H. I don't believe they have anything to do with the headlight door issue and plan to address them at a later date. I'm thinking that the HDMS has failed but wonder if the MFTS should be sending both on and off signals at the same time. I would like to make sure I am making the correct repair without guessing. Anyone have the answers to these two questions?
Old Feb 28, 2017 | 12:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a POWER side of the HDMS. There is also a schematic of the control side.
The HDMS always applies power to one motor or the other. The Head light assembly does not have limit switches. The HDMS senses a raise in drive current when the module enters the UP- or Down limits and the HDMS stops driving the motor.
Old Feb 28, 2017 | 01:16 PM
parrottp's Avatar
parrottp
Shouldn't the ABCD output terminals on the HDCM only have power on either up or down at one time? It looks to me like it is telling the doors to go both directions at the same time. Shouldn't A and D or B and C be hot and not all 4 at the same time?
To Headlight Door Not Opening
