Won't start need help!
Old Mar 6, 2017 | 04:06 PM
Ehastings32's Avatar
Ehastings32
Default Won't start need help!
Did a total rebuild on my 99 FRC and put everything back the way it was except starter. Tried starting it and would just click. Figured out I had a ground wire mixed in and it was attached to the Celanoid /starter wire. After fixing that I tried starting it again and all it does is turn over. I can smell fuel but it seems to not be getting spark? could there be a fuse out? Any knowledge would help!!
thanks in advance
Old Mar 7, 2017 | 02:34 PM
mmartinez's Avatar
mmartinez
There is a ground connection at the rear of the cylinder heads that are used for the coil packs, check there first.
Old Mar 7, 2017 | 10:03 PM
Rob 02's Avatar
Rob 02
To Won't start need help!
