1998 ABS/TCS question
The car belonged to my in laws who have ran into problems because of health problems.
I have replaced the battery as the car had to be jumped several times over the past.
The car has set for some time but the the problem was there before it set.
I forgot to add I am getting the 1226,1233 and 1255. I also read Bills sticky on the connectors which I plan on looking at, along with flushing the brake fluid.
I also looked at the sticky for the retro fit for the 99-00 from the 01-04 ecbm, and I will assume it doesn't work for the 97-98. So with all this being said..well written..the question is , is there a fix for the 98?
mace
mace
Wish me luck
mace
The C1226 and C1233 are both pointing to a Right Front wheel speed sensor. The sensors themselves almost never fail. The problem there is MOST likely damage to the wiring at the right front wheel or the connector to the sensor has corrosion or deformed contacts. The pins in the connector are very prone to deformation. Put the front up on jack stands and take off the RF wheel. Examine the wiring on both sides of the WSS connector for damage and repair as needed. If the wiring is good then separate the two halves of the connector and examine for corrosion or deformed pins. Clean up any corrosion and reshape the contact surfaces in the connector as needed and plug back in. A dental pick works great for reshaping the contact surfaces.
Clear the codes and then pull the codes again after you have taken the car for a ride. Post back all codes (5 characters) that have come back.
You never responded to my question in post #4 on whether the 1255 code was a C1255 or a U1255.
We can take it from there once you post back ALL the codes that come back..........
Now to throw another clinker into the mix. There were two levels of EBTCMs for the rear system. The 97s and some 98s were delivered with a design problem and had trouble tracking wheel speeds properly. They would set the C1226 or C1233 or similar codes due to losing a lock on the wheel speed signal frequency. Some time in late 97 or early 98 Delphi redesigned the unit to cure the problem. The redesigned unit with a new part number hit the GM Repair Parts Inventory some time in the last half of 99. I had been having this problem with my 97 and had the EBTCM replaced under warranty as soon as the redesigned part was available. I just tried to look up the part number for the redesigned unit but in the close to 18 years since I was involved in this it has disappeared from my data base.
Hope an pray cleaning all of the electrical connections resolves your problem. It is likely if the car is stock that the EBTCM was never swapped for the redesigned unit. The failure usually only occurred on cars that were being autocrossed and the ABS would fail in the middle of a run resulting in a fair number of flat spotted tires.
Bill
The SWPS for the 01+ systems has 2 less wires then the 00- systems. The yaw and accelerometer each require an extra wire. So, the necessary wires are available to use for retrofitting these sensors.
As for repairing. The EBTCM modules that fail due to the main control circuit board failing are essentially not repairable, simply due to the way the board is made and installed into the module. If the module is not responsive to diagnostic code checks and you've double checked all the wiring then the module is garbage. Lots of people have paid various repair companies to attempt to fix them with no luck.
The EBTCM as well as all the other C5 electrical modules are extremely sensitive to improper electrical voltages. Before you get too wrapped up in module failure, you need to make sure that you:
- Have a proper battery in 100% working order
- Power to the module needs to be measured with a DC Volt meter at the supply fuses to be sure that you have FULL Battery voltage at that fuse.
- Module Grounds need to be verified clean and tight and have minimal resistance to chassis ground.
Battery Chassis ground wire G-104/108 needs to be cleaned and minimal resistance to chassis ground.
Once ALL of that is in proper order, Clear ALL the DTCs and see if you still have issues with 1255. Like 8vette7 stated, you need to determine if it a C or U prefix. The "C" could be module Power and or Ground related.
As 8VETTE7 stated, the female pins are prone to spreading and will cause 1226,1233 DTC C1221-C1235 Wheel Speed Sensor Circuit
NOTE! The EBTCM DTCs need to be pulled and read WITH OUT turning the ignition switch to OFF and back on. The EBTCM runs a start up process check and some DTCs that pop in that ignition cycle are cleared when you turn the ignition OFF and them ON.
New connector on the LEFT,,, BAD pins on the right!!
Also,that ou for the great info. When I get a free moment I plan to start cleaning connections.
Thank you all again
mace
The first thing I did was replace the battery as it was almost 5 years old and they had to jump it to start it.
I'm getting tires on it today and asked them to look at the right front hub assembly while the wheel is off.
Like I said, I am trying to get this thing road worthy, there are cob webs under it it sat so long.
BUt something weird today, while running to get tires put on no abs/tcs lights...what do you think.
Thanks again
mace
1 favor, when I began looking at this I found a youtube video on how to clear the codes, if someome could point me to that I's appreciate it .
mace
