Where is this oil leak coming from
Under the car this evening and noticed some oil around the oil pan.. no noticeble drips on the floor. What does this look like to you guys?
Look up to the oil dipstick where it goes into the block. Look at the low oil sensor. Check your valve cover screws for tightness. Doesn't look like a huge leak, just some seepage. Could also be something on top as oil travels funny paths to reach the bottom of the block.
unlvrebel (04-03-2017)
So I got under the car today and cleaned everything off. I thought this was odd tho.. I was lifting the front end first and when I got it off the ground a good bit I heard a liquid draining... I looked under the car and water was pouring out of the flanges of the xpipe/axleback. I check and the bolts were a little loose but not bad, couple turns each.. here is a pic I took right after it leaked out, notice the puddle on the floor. Obviously I have an exhaust leak but I dont see how water just poured out....
My concern isn't the water it is how that water made it's way out of the pipes so easily. Because of the leaking and the amount of black soot on both sides I assume I have a pretty bad leak. I know it's not really a big deal though but I believe I am going to try using two gaskets instead of one on both sides and see what does... maybe some sort of gasket sealer as well.
