Advice on my build direction?
Old Apr 4, 2017 | 03:52 AM
halokiller's Avatar
halokiller
Default Advice on my build direction?
Hello,
I am debating what the best direction is with my build in terms of bang for buck. My current setup is a 416 LS3 with ported 243s, a 220/224 .581/.581 114 lsa cam, FAST 78mm, and JBA shorties. I plan on doing 1 7/8ths long tubes headers and a FAST 102mm regardless of my build direction, but I wanted the forum's advice on whether to install a bigger cam (around a 23x/25x .6xx/.6xx 112 LSA) or invest in nitrous instead. My current setup is making 430rwhp/445rwtq but it is very restricted on the intake and exhaust side. Is the cost of the cam swap worth it, or should I install headers and a the 102mm intake and run nitrous? Trying to decide what the better budget build is
Old Apr 4, 2017 | 07:18 AM
vettenuts's Avatar
vettenuts
Since you can do the headers and intake without opening the motor and you can install a cam without removing headers and intake, why not install the headers and intake and see where you are then decide on a cam. Would also give you an idea on what the intake and exhaust restrictions were doing to performance.
Old Apr 4, 2017 | 11:26 AM
halokiller's Avatar
halokiller
That's true, the only thing is that I would have to tune twice with that approach
Old Apr 5, 2017 | 10:52 AM
halokiller's Avatar
halokiller
Bump!
To Advice on my build direction?
