Odometer error
Old Apr 6, 2017 | 07:24 PM
silver97's Avatar
silver97
Default Odometer error
I had to replace the battery on my 1997 C5. Now instead of showing the mileage of the car it has "error" there. I have disconnected and reconnected the battery, checked for codes (found none), disconnected the battery along with turning it on but still shows "error" instead of the mileage. What is the fix? Thanks
Old Apr 6, 2017 | 08:47 PM
Velocity_Vette's Avatar
Velocity_Vette
1) Does your cluster still perform a gauge sweep upon turning the ignition on (not starting the car)?
2) Can you select any of the trip options via the DIC?
Old Apr 6, 2017 | 09:12 PM
silver97's Avatar
silver97
1) Yes it does sweep.
2) Yes I can access the rest of the trip options.
I can start the car and everything else functions like it should.
Old Apr 7, 2017 | 01:23 AM
grantv's Avatar
grantv
I'm no expert with electric stuff, but...
1. What caused the battery replacement, and what were the symptoms that caused you to replace it?
2. Have you had the new battery tested? New does not guarantee no faults/issues, may be a faulty cell or?
Old Apr 7, 2017 | 05:21 AM
silver97's Avatar
silver97
1. I had the trickle charger on and came into the garage and heard a clicking noise. The trickle charger was cycling on and off as it tried to charge. Took battery out and it read only 8.5 volts not 12.
2. No have not had new battery tested but car does start and the trickle charger is working on it.
Good question. I will have it tested also. Thanks!
Old Apr 7, 2017 | 11:46 AM
Velocity_Vette
The odometer mileage is stored in the IPC in the gauge cluster. It is possible that it has failed for some reason or another.
I believe that there is a DIC code that is thrown when communication with the IPC, PCM or BCM is lost. Sorry I dunno which it is specifically but it would be pull-able from the DIC as it still is functioning.
Old Apr 7, 2017 | 12:12 PM
silver97's Avatar
silver97
Thanks! I read the DIC and there are no codes. From what I have read is it is corrupted and has to be sent in to be repaired.
To Odometer error
