2004 lumbar not working
https://www.corvetteforum.com/forums...ters-pics.html
to believe anything would not be working. Car has been extremely well taken care of. I'll check the website you suggested. Thanks again. GP bill
Another thot from me which is that when trying to activate a lumbar switch just after starting the car, you hear a momentary buzz then nothing. Like something is shorting out. Any thots about this?
On the noise you hear when pressing the switch, that is the pump motor running. There will be no noise from the pump when deflating the lumbar just when inflating.
There are a couple of threads on the forum for replacing the plastic bladders with latex blood pressure cuffs.
Gary
https://www.corvetteforum.com/forums...vil-style.html
Gary
Is there another relay or circuit breaker in the seat control module that could be tripping? (the main seat relay/breaker is fine) I'm planning on removing the seat to check out the control module, but is there anything specific I should be looking for? (would cold solder joints cause an issue like this?)
Also, based on my passenger seat, the motors should be running whether you are inflating or deflating the lumbar pads.
G'pa Bill
--Mike
--Mike
I would recommend that you first check the lumbar bladders to make sure that they are in good condition, and the hoses are attached properly, there seem to be a number of them that fail, and the fix for that appears much simpler. Mine were in great shape, and held air just fine, so I started looking elsewhere.
I pulled my drivers seat out of the car, and followed the directions from others, who recommended pulling out the SCM and touching up the solder points on the board. This did not fix the problem, so I moved on to the switch board, since that was another recommendation, and unless you've had a quite a bit of water in your car, I wouldn't bother with this. The switch panel case is plastic welded together in two spots, and I had to drill those out before I could get to the board. Once I did, there was no trace of any corrosion, so I cleaned it anyways,and stuck it back together, with no change to my problem.
While I was testing the seat the second time, I noticed that when the lumbar pump did run, it always seems to die when it hit the two extremes of the range, either all the way inflated or all the way deflated, at which point the motor would make a da-da-da sound and then stop, and not work any more. Under the seat are two vinyl bags closed by zip ties, The black bag is the lumbar pump, and hanging from the seat springs is a white/cream colored bag that contains the lumbar solenoids and relays. I pulled the white bag out, and clipped the zip tie so I could pull out the board inside. I hooked the seat back up to the car, and noticed that when the lumbar pump stopped working, if I touched a screwdriver to the metal contacts on the large gray air pressure switch on the board (has a single air line connection on top), the lumbar pump would start working for a while until it reached the max or min value, and then I'd have to touch the contacts again. So I thought the air pressure switch was bad, but just for grins and since I didn't have a replacement, I tried touching up all the solder points on the solenoid board, including the air pressure switch. I also noticed that the switch has two small screws on it, one on each side, which appear to be for adjusting the switch trip pressure. I turned each screw about a quarter of a turn, and then reset them back to their original setting. I hooked it up again, and so far it's been working perfectly. The one difference that I noticed now that it was working properly, was that the pump didn't make the stutter-stop sound when it hit the limit switch, it just stops, and then you can run it in the opposite direction.
Hope that helps a little.
--Mike
--Mike
--Mike
https://www.corvetteforum.com/forums...t-problem.html
Good Luck!
--Mike
