N2MB WOT Box Wiring
Old May 19, 2017 | 01:17 PM
Richard A. Snitzer's Avatar
Richard A. Snitzer
Default Fusebox UHBEC Connector Separation
I just went through this.
Use a 1/4" ratchet with 9/32 deep well socket. If you don't know which connector you want to take off, it is the one closest to the passenger quarter panel or B+ post on the side of the UHBEC.
Greg and I are putting together much better instructions. IF you cannot wait, PM me with email and I will send better pix than the instructions. It will be next weekend until I get this all put together.
Originally Posted by Efx
Any tips on how to separate the fusebox Fuses section and lower wires modules. Would make it easier to solder.
Old May 19, 2017 | 01:27 PM
Richard A. Snitzer
Default Some much better pix
Guys,
Sorry I have been busy with my own install. With the help of Greg and belatedly, N2MB, I am done with the physical install. Not the programming.
Here are the pix I have taken. I plan on putting together a job aid with corrective editing N2MB has on their website for the 2004. Should be the same for 99-04.
It will take me until next weekend I am guessing to finish.
Can anyone confirm
Does A6 pin = red wire from wot box
Does E2 pin = Orange wire from wot box?
​​​​​​​Thanks
Old May 19, 2017 | 01:30 PM
Richard A. Snitzer
Default Pink Wires in Fusebox
This was a direct question to N2MB last night. When you cut A6 & E2, the "leads to the fusebox" are the short leads that are still attached to the fusebox. The "from" is the leads headed towards the ground/pavement.
When they are talking about 2 pink wires on Pin E2 and pin A6, Red wire from WOTbox connected to wire ends that lead TO the fusebox and orange wire connected to wire that lead to the coils...
Which pink wire leads to the fusebox and which leads to the coils?
Old May 19, 2017 | 01:32 PM
Efx's Avatar
Efx
These are great. I noticed you connected YELLOW wire to purple wire in pin 56. Are instructions wrong? it mentions C2-26..with red cover
Old May 19, 2017 | 01:35 PM
Richard A. Snitzer
Default PPL Wire
Sorry!
That was before I talked to N2MB last night. The correct splice is the Green Connector Pin 26 PPL.
I need to delete that photo.
Old May 19, 2017 | 01:41 PM
493lszosix's Avatar
493lszosix
[QUOTE=Efx;1594770699]Will update this thread with my progress. If anyone could confirm my wiring, that would be great... Also my box came with parameters set for srt4 dodge. Can anyone share their settings that work for c5z?
It may be a day or two till I have a chance but I can see if I can get a screenshot of mine and post it
Old May 19, 2017 | 01:44 PM
Efx's Avatar
Efx
Ok so instructions on the website are partially wrong...
Are these correct?:
WOTBOX Blue wire -> Dark green wire Accelerator pedal sensor (at the pedal)
WOTBOX Green wire -> Grey wire Clutch switch sensor (at clutch pedal)
WOTBOX Black wire - ground
WOTBOX RED wire -> A6/E2 pink wires going in to Fusebox (cut)
WOTBOX ORANGE wire -> pink wires going to coil packs (cut)
WOTBOX YELLOW wire -> PCM pin 26 with GREEN inside cover
Old May 19, 2017 | 01:54 PM
Richard A. Snitzer
Default You got it.
I highly recommend soldering even though it is a PITA.
Are these correct?:
Old May 19, 2017 | 02:14 PM
Greg_E's Avatar
Greg_E
Are these correct?:
Only 2004 has green PCM C2 connector. 1999-2003 PCM C2 is red. See post #33.
That looks good to me.
Rich will be adding his notes and comments to this document when he gets time, but I'm going to post it now. Hopefully it will help clear things up.
Current revision is D
See post #35 for a wiring diagram I did. If anyone finds anything in either document that is incorrect, let me know and I will fix it.
Old May 19, 2017 | 02:27 PM
Efx's Avatar
Efx
edited.
Old May 19, 2017 | 06:43 PM
Greg_E's Avatar
Greg_E
Efx: Can you delete the Revision A pdf in post #30. I've added some information to make it easier to find C1-A6 and C1-E2 on the Under Hood Electrical Center.
This is still a work in progress.
Old May 19, 2017 | 06:44 PM
Efx's Avatar
Efx
Well Im in a pickle. I am not sure if I wired the yellow wire correct the first time or I am doing something wrong.
my c5z is 2003 and my PCM are red and blue.
Blue pcm pin 26 does not have purple wire
Red pcm pin 26 has purple wire where I connected the yellow one to.
Here the PCM with red connector with pin 26 purple wire
Here is 2nd PCM with blue connector, pin 26 is not purple wire
Here is overview of both PCMs unplugged
So confused
Old May 19, 2017 | 06:58 PM
  #33
Greg_E's Avatar
Greg_E
You did it correctly. C2 is the red connector. You do need to solder the purple wire that is dangling, to the purple and yellow wires if you haven't already done that.
I remember reading that they changed the connector color. Don't know what year that was.
I'll see if I can find it.
Even if the color of the connector changed, the wiring diagram didn't.
From the N2MB instructions:
"For 1999-2004 vehicles, the PCM connector with the red inner cover is the C2 connector"
That may only be partially true. It may have changed from red to green in 2004. We need to look into this.
Update:
Found it. 2004 Blue and Green Connectors. 2003 Blue and Red Connectors
1999-2003 C1 is Blue, C2 is Red. I think they made some changes to the 2004 PCM and changed the C2 connector to Green
http://corvetteforum.shelor.net/Corv...ts/Default.asp
Old May 19, 2017 | 08:15 PM
  #34
Efx's Avatar
Efx
Yes I did solder the wires. Just took a pic prior to that for reference. Everything plugged in. Took 2 screenshots of the software for n2tmb to make sure everything wired up ok. Waiting for reply.
Will keep this thread updated with results.
Thanks again to everyone for their input. N2MB support has been outstanding btw.
Old May 20, 2017 | 12:06 PM
  #35
Greg_E's Avatar
Greg_E
Can someone who has actually installed one of these check this wiring diagram and let me know if there are any errors or omissions.
My skills with MS Paint are about nil.
File Type: pdf
Last edited by Greg_E; May 21, 2017 at 06:35 PM. Reason: Revision C. No changes. Just cleaned up the drawing.
Old May 20, 2017 | 11:10 PM
  #36
Efx's Avatar
Efx
Your diagram is bang on.
With the help of this forum and Jon, i was able to wire and test the unit.
Everything works as it should. PM me if anyone needs more details about my install. I will post more pics of my wiring.
Part 2: i am cleaning out the mufflers from blown cats lol.
Old May 22, 2017 | 10:33 AM
  #37
nsogiba's Avatar
nsogiba
Would love to see pics of your install, and videos of testing.
What are your initial parameter settings?
To N2MB WOT Box Wiring
Old May 22, 2017 | 10:55 AM
  #38
TX Z06 02's Avatar
TX Z06 02
Need some help from you guys. I did my install this weekend: everything per instructions (and what I read here) except the trigger i tied into my brake light since im automatic.
The testing is NOT working out.
I ran the setup, downloaded new firmware, etc. I then did the first
"READ" and saw that the TPS V was at 4.10, so I inverted the signal and both showed "UP" on the vehicle snapshot.
Then I mash the accelerator to the floor, the voltage changes, but it still shows "UP"
I even adjusted the TPS Threshold (V) and it still never seemed to work.
Anyone have any screen shots of their WOT Box User Interface with their setup?
Accelerator wire tap:
WOT Box install:
Old May 22, 2017 | 02:35 PM
  #39
Greg_E's Avatar
Greg_E
I'm not sure I can help you, but what wire did you splice into on the brake switch?
Old May 22, 2017 | 02:38 PM
  #40
TX Z06 02's Avatar
TX Z06 02
If I am not mistaken, there are 3 wires to the lower switch, orange, white and light blue. I tied into the light blue.
