Hard Start
Old May 19, 2017 | 10:48 AM
B81jll's Avatar
B81jll
Default Hard Start
Started my 97 c5 the other day (has 2002 computer) car started quick and fine as normal.. shut the car off after about 10-15 seconds because i couldnt hear what someone was saying outside the car.. now everytime i go to start the car it cranks for ever before it wants to start.. if it starts at all, sometimes i have to hold the gas to the floor to get it to start
Old May 19, 2017 | 11:26 AM
B81jll's Avatar
B81jll
thank you for your reply, may be the issue.. because when the car starts it runs fine.. it also has aftermarket rails and fuel pressure regulator. It was just odd because it just all at once did this and if i hold it to the floor it starts up
Old May 19, 2017 | 02:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Peddle to the floor during start is how injected cars are CLEAR FLOOD STARTED. Sounds like something is causing a very rich mixture issue.
Try and start the car without doing the clear flood and if it doesn't start, Pull the plugs and inspect them. See if one plug or one bank is WET with fuel.
Have you checked the DTCs using the DIC??
Bill
Old May 19, 2017 | 03:00 PM
B81jll's Avatar
B81jll
ill try these things and post back, i apprciate the input guys. ill check the dtc today
Old May 19, 2017 | 07:13 PM
B81jll's Avatar
B81jll
Alright guys.. pulled the codes and it's throwing a cam sensor code.. just did cam swap and had tuned.. put about 250 miles on it.. afraid it may be cam bolts.. what's yalls opinion
Old May 19, 2017 | 07:38 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can pull off the intake and the valve valley cover and see the back of the cam gear If its loose, you can tell from there.
Bill
Old May 19, 2017 | 07:40 PM
B81jll's Avatar
B81jll
Bill
I will try this.. I appreciate your help!!! Hopefully it's something simple as this
Old May 22, 2017 | 07:52 AM
B81jll's Avatar
B81jll
Bill
Thanks again Bill, Pulled the motor apart and it was the cam bolts... Cars back together and it starts flawlessly
To Hard Start
