Key FOB Training Missing-99 C5
Old May 25, 2017 | 10:35 AM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Key FOB Training Missing-99 C5
Good Morning,
I had my car at the tuner for mods and I'm happy with the results, 365 RWHP, but my FOB would not work. Thinking they had the battery disconnects and I would just need to go through the DIC and reprogram. Well I no longer have the FOB training available. Just curious if anyone else has ever experienced this ???
Thanks,
Jim
Old May 25, 2017 | 11:10 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by BRAVO1
Good Morning,
Thanks,
Jim
Jim
Use the DIC and read the DTCs and see if you have DTCs or NO COMMS for the RFA.
Are you able to read tire pressures and does the info change if you add or remove air?
If you have DTCs, CLEAR ALL of them and see what returns. Report those.
Bill
Old May 25, 2017 | 11:12 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can also press and hold the LOCK & UN-LOCK on the FOB down at the same time for 15-30 seconds until the horn toots and that will RESYNC the fobs back to the car.
Bill
Old May 25, 2017 | 05:00 PM
BRAVO1's Avatar
BRAVO1
VETERAN
In the B0 - RFA I have an B2860H
Telescope Column Position Sensor Failure.....
FOBs worked before mods and dyno tuning.....
Jim
Old May 25, 2017 | 05:13 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Bill
Bill,
This does not work.....
Jim
Old May 25, 2017 | 05:16 PM
Carl Timonen's Avatar
Carl Timonen
Did you clear that code?
Old May 25, 2017 | 10:13 PM
WEEKNFRC's Avatar
WEEKNFRC
3rd Gear
Bill,
Jim
Hello Jim, I am having exactly the same problem. The Key Fob Training Option disappeared completely from the DIC. Now I am on a quest to figure out how to add that option back into the BCM. If I have any success, I will certainly share that information.
Thanks,
Walter
Old May 25, 2017 | 10:44 PM
BRAVO1's Avatar
BRAVO1
VETERAN
I will tomorrow......
I'll let you know..
Jim
Old May 25, 2017 | 11:06 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Originally Posted by 8VETTE7
B2860 is NOT a B0 - RFA related code. Rather it is an A6 - SCM (Seat Control Module) related code.
I suggest that you want to re-pull the codes and carefully write them down.
Is it possible that sensor B0 - RFA is not showing up at all when you pull the codes????
You're right...sorry wrote the codes too quickly...I have:
U1096H
U1064H
U1016H
Old May 25, 2017 | 11:19 PM
WEEKNFRC's Avatar
WEEKNFRC
3rd Gear
U1096H
U1064H
U1016H
Gentlemen, again, those are exactly the same codes I am getting (BO-RFA - Remote Function Actuation)
Old May 26, 2017 | 06:20 AM
BRAVO1's Avatar
BRAVO1
VETERAN
10 - PCM......no codes
28 - TCS......C1221H
C1222H
C1255H
38 - RTD......C1790H
40 - BCM......no codes
A0 - LDCM....B2262H
A6 - SCM.....B2607H
B2860H
B0 - RFA......U1096H
U1064H
U1016H
I will clear all codes and take a long ride today and see what comes back...
To Key FOB Training Missing-99 C5
