98 C5 CMP sensor fault
Old May 25, 2017 | 03:15 PM
BobS98's Avatar
BobS98
Default 98 C5 CMP sensor fault
I know where the sensor is at and what is involved replacing it. But, is it possible to access the connector, to check electrically, without removing the manifold our hiring a real tiny assistant.
Bob
Old May 26, 2017 | 12:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bob
Here is the schematic. Go to the PCM connector and check there:
Old May 26, 2017 | 12:13 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the PCM Schematic for your year car. Cant remember what year that schematic is from.
BC
Old May 26, 2017 | 03:47 PM
Greg_E's Avatar
Greg_E
BC
For a 1998 The connections at the PCM are as follows.
Low Ref C2-70
Ign. Feed C2-4
CMP Sensor Signal Input C1-4
The circuit numbers and wire colors are the same as the schematic Bill posted
To 98 C5 CMP sensor fault
