Passenger side valve cover port
Old Jun 2, 2017 | 08:43 AM
99blkfrc99's Avatar
99blkfrc99
Default Passenger side valve cover port
I switched intakes and throttle bodies so I have nowhere the run this port too. What should I do? Thanks all!
Old Jun 2, 2017 | 08:44 AM
99blkfrc99's Avatar
99blkfrc99
Old Jun 2, 2017 | 11:14 AM
nsogiba's Avatar
nsogiba
Cap it. Make sure you have some sort of adequate crankcase ventilation, though.
Old Jun 2, 2017 | 12:07 PM
99blkfrc99's Avatar
99blkfrc99
I do have the pcv still hooked up. Is that good enough?
Old Jun 2, 2017 | 12:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO! I DO NOT AGREE!
I have/had the same issue when I went with a FAST 90/90MM TB. The engine crank case ventilation is very important. The PCM is set up to account for an exact amount of crankcase ventilation (even in different engine load/throttle opening scenarios) If you cap it off:
1. You will not have an adequate supply of MAF metered fresh air to supply the block and PCV.
If you leave it open, you will be sucking is non filtered and non metered air.
Here is how I solved it on my engine. On the drivers side of the air bridge is a FLAT Spot. I drilled a hole into it and threaded in a BRASS fitting with a barbed nipple that would fit the vacuum line that comes off that PCV Vent nipple. I ran the hose under the TB and to that new brass nipple. Now I have a proper supply of fresh, filtered & properly metered air for the PCV System.
Old Jun 2, 2017 | 12:42 PM
Sam Handwich's Avatar
Sam Handwich
Originally Posted by Bill Curlee
NO! I DO NOT AGREE!
Bill, you have a picture for everything. (hint, hint, ya know what I am thinking?)
thanks
Old Jun 2, 2017 | 12:45 PM
99blkfrc99's Avatar
99blkfrc99
Thank you for the response.
Old Jun 2, 2017 | 12:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When I first did my heads/cam/fast90 install, I was under a time crunch to get the car on the road to take it to Bowling Green. I,, like you, had the exact same dilemma.
Not wanting to cap it and wanting to make it properly functional as quick as possible, I punched a small hole into the rubber coupler between the bridge and TB, threaded in a small shallow brass fitting into the rubber coupler and hooked the hose up temporarily there.
To make it a more permanent install, I moved it to the other side of the air bridge. I don't have any pictures of that install as of this writing.
Old Jun 2, 2017 | 01:16 PM
99blkfrc99's Avatar
99blkfrc99
so just plumb it somewhere in the intake pipe. Does it have to be after the maf?
Old Jun 2, 2017 | 01:28 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES! Between the MAF and TB.
Look on the drivers side of the OEM plastic Air Bridge. You will see a round FLAT SPOT on the SIDE of the plastic air bridge. Go to AutoZone or even Home Depot, look in the brass fitting section for a 90 deg fitting that has a threaded end and a barbed hose nipple.
Find a drill bit that is a little smaller than the threaded end and drill a hole into the air bridge. Use a little firm pressure and crank the fitting into the hole. It will thread in like it was a factory part!
Simple and easy!
Old Jun 2, 2017 | 01:34 PM
99blkfrc99's Avatar
99blkfrc99
thanks so much!
Old Jun 4, 2017 | 08:09 PM
maj75's Avatar
maj75
Best is to swap in an LS6 valley pan. That's what I did. I run the PVC in the valley pan to a catch can and from there to the port on the throttle body. Simplifies PVC plumbing.
FWIW Z06 and later Vettes do not use these valve covers. They moved the PVC to the valley pan.
Old Jun 4, 2017 | 08:25 PM
99blkfrc99's Avatar
99blkfrc99
Thats exactly what a was researching last night. Thanks for the info
Old Jun 4, 2017 | 11:20 PM
99blkfrc99's Avatar
99blkfrc99
where is the best place to get a valley cover and catch can?
Old Jun 5, 2017 | 06:40 AM
vettenuts's Avatar
vettenuts
Please tell me that's not SNOW
Old Jun 5, 2017 | 11:05 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WHY,,, YES IT IS! A good forum member asked me to take a picture of something in the middle of a SNOW STORM, so,,, I got my boots on and went out and took the pictures!
That vent was a quick work around to get the car on a road after the head cam fast 90 install. I have since made it a permanent install with that 90 deg brass fitting on the side of the air bridge.
Bill
Old Jun 5, 2017 | 08:08 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
I was wondering how long it would take for the snow question??? Bill,, Dollars to donuts, you have turned a few wrenches in the snow too.. LOL
mike v
To Passenger side valve cover port
Old Jun 8, 2017 | 01:11 PM
David@MMS's Avatar
David@MMS
Supporting Vendor
when you switch away from a throttle body with a port at the top of it, you just need to connect out in front of it somewhere.
it is not intuitive but the port on top of the throttle body routes internally to in front of the blade, so all you have to do is mimic that.
this is where the pcv gets its fresh air supply from, so it is important that it is firstly measured by the MAF sensor before use to keep the computer happy.
there are a few photos mixed in at the bottom of my customer gallery link here of how some customers have done it.
https://drive.google.com/drive/folde...V9LN2M1Q0IyUGs
the ls6+ ported valley cover is a fine replacement for the older 'floating' pcv valve assembly. make sure you get the cover with the pcv built into it, as one of the original version still required an external valve.
while the ported valley is a more modern feature i like it only because of the built in pcv and not for measurably better oil control in my experience. either application for best consumption control a catch can is the right choice.
alternately with my max effort system (PCV can on my site), the pcv control is built into the can, so any other pcv valve or orifice on the car can be eliminated all together for better crankcase pressure (and clean side oil) control.
__________________
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
Old Jun 8, 2017 | 01:31 PM
99blkfrc99's Avatar
99blkfrc99
I was not planning on doing an LS6 valley cover unless I totally have too. Can you send me a link to your can, I'm interested. Thanks.
Old Jun 8, 2017 | 01:39 PM
99blkfrc99's Avatar
99blkfrc99
That's what I came up with the other day. Just plumbed it into the intake pipe that I made.
