Re installing timing chain cover
Old Jun 5, 2017 | 06:53 PM
CharlieC5Z06's Avatar
CharlieC5Z06
Default Re installing timing chain cover
So I am replacing the front main seal and timing cover gasket. I have the cover off and new seals. My question is. Is the lower seal on the oil pan connected all the way around the oil pan? If so I'm guessing I have to reuse that seal and just use some rtv? The new seal is just for the top and sides of the cover. Any good tips on how to get this thing on and have least chance of leaks since that's why I'm changing it now. Thanks.
Old Jun 5, 2017 | 07:12 PM
feeder82's Avatar
feeder82
put a little rtv in the corners, and use a cover alignment tool if you plan on keeping the car
Old Jun 5, 2017 | 07:15 PM
CharlieC5Z06
Ok thanks. So leave the bottom seal alone just reuse it and put rtv in the corners. No rtv with the regular seal right? Yeah I'm gonna order an alignment tool now. I doubt any store will have them right?
Old Jun 5, 2017 | 07:44 PM
feeder82's Avatar
feeder82
saccity corvette a forum vendor has them for sale
Old Jun 6, 2017 | 07:41 AM
vettenuts's Avatar
vettenuts
The tool centers it on the crankshaft. I used a finely graduated six inch metal rule to do this but the tool is much easier as centering it requires some compression of the pan gasket so its a bit tedious without the tool.
Not sure how the Sac City tool works, it might require the seal to be out for cover installation so don't install the new seal until you find out. The new seal usually presses in with your fingers so installation is simple.
Old Jun 6, 2017 | 08:17 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
That is correct. The SacCity tool "locates" on the indentation where the seal presses into.
Old Jun 6, 2017 | 09:55 AM
Darrell98's Avatar
Darrell98
Would it be possible for you to post some pictures ? I would like to see how this is done so if I have to do this in the future I understand the procedure. Thanks Darrell
Old Jun 6, 2017 | 03:04 PM
StingrayRebel's Avatar
StingrayRebel
Old Jun 7, 2017 | 09:53 PM
Darrell98's Avatar
Darrell98
Thank you to neutron82 for posting the video. That answered my question. Darrell
Old Jun 7, 2017 | 10:16 PM
foggy's Avatar
foggy
I am in KC area if you want to borrow mine.. I have both tools.
Didn't see in sig where you are
To Re installing timing chain cover
