What is this knocking sound
Old Sep 30, 2002 | 09:22 AM
 Al's Avatar
Al
Default What is this knocking sound
I have a 02 vette-- every time I start the car I hear a knocking sound from the engine the sound is about twice a second when idleing it lasts for about a minute then it goes away, I have 3000 miles on the car and no mods. should I be concerned or what can I do to give you more information on this or to pin point what it might be ?? :confused:
Old Sep 30, 2002 | 10:02 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: What is this knocking sound ( Al)
Does the knocking sound increase with engine rpms?
vetterdstr :cheers:
Old Sep 30, 2002 | 01:26 PM
 Al's Avatar
Al
Default Re: What is this knocking sound (vetterdstr)
No it does not increase with higher rpm or maybe I just dont hear it because of the higher engine noise , but like I said it does go away after about a minute.
Old Sep 30, 2002 | 01:45 PM
rrobert22's Avatar
rrobert22
What you have is..........well, a corvette, and its gonna make some noises :yesnod: Seriously though my red vert did that, I think Its just the lifters filling with oil, or could be the fuel injectors, I dont really know :cheers:
Old Sep 30, 2002 | 06:55 PM
carpe dm's Avatar
carpe dm
Lifters, injectors, piston "slap", exhaust leak, emission systems valve, etc. ....... :confused: Unless it gets worse, you are probably OK, as all of these have been know to cause the noise and are "normal", according to the General's techs. What weight oil are you using? If it is a lifter, changing back to a 5W-30 or 0W-30W would help. :yesnod: :)
To What is this knocking sound
